I wanted to add that in fact the value 544 WLTP was not really used because the first Tesla Model 3 arrived in France and Europe in spring 2019 with 560wltp.
Thanks. I think this makes sense then. The first highly publicized efficiency boosting software update was released in early 2019 (was announced Feb 28th, 2019, released one month later), as I recall, just
after the 560km WLTP result you give (if the WLTP result was released in early 2019 it was probably conducted a month or two earlier).
The 2019 and 2018 EPA efficiencies were also the same for AWD (not in all the tables I publish here because normally I hide the 2018 results because they are redundant), so it would make sense the 560km WLTP in early 2019 would be the number to look at as the reference.
Not sure what to make of the 544km number but that predates any deliveries as you say. It’s possible it was an early AWD test with capacity lock similar to the initial RWD before capacity unlock. Math doesn’t quite work (325/310*544 = 570, not 560). Shrug.
Anyway, sounds correct. The 560km WLTP number was achieved with a 2019 vehicle that was 7% less efficient, and with 3.5% more capacity (again, to be clear, NOW those early 2019 vehicles are ~7% more efficient than they were when delivered, in other words about the same efficiency as 2021!).
Now 2021 has ~3.5% less energy than that test article, but is 7% more efficient than that 2019 article. So it goes (about) 3.5% further. (
560km/0.93 * 75kWh/77.8kWh = 580.47km)
And to set Timothy’s mind and beating heart at ease (since he seems to be thinking I believe otherwise even though I obviously, explicitly, repeatedly state that I do not): if you were to find an undegraded 2019 vehicle, and perform a WLTP range test vs. 2021, 2019 would have about 3.5% more range than the 2021 (~600km WLTP). Because the 2019 NOW has similar efficiency to 2021, but more energy! In other words, the 2019 has ~7% (actually 7.5%) more WLTP range than it did originally, because it is 7% more efficient than it was when it was tested!
So another way to look at it is that recent 2020s had 600km WLTP range (never tested), and now the 2021s have 580km range. (This statement will make Timothy happy, I think, though he is quite difficult to please!)
The 2021 AWD vehicles sold in the US would have 600km WLTP (or about 620km WLTP for a hypothetical 2021 Performance (Europe or US) in Stealth config).
Crazy that in Europe the 2021 Performance has 7% more unlocked capacity than the regular 2021! Buy the Performance, folks! It has much better range potential when properly equipped with range wheels and tires!
