I think everyone knows what the problem is, everyone has experienced it, and Unplugged and MPP are trying to figure it out a solution. Tesla’s “track mode” is hardly track worthy as the red battery keeps on popping up and of course the car is try to protect itself. I appreciate when the manufacturers spend the time to test and not send out a half baked version despite the masses wanting it.
The question comes that if there is an aftermarket solution to prolong the “time” to track the car does it ultimately wear down the components (battery /DUs). I’d figure it’s better the same concept of ICE cars. Just because you are able to prolong components in that moment doesn’t mean inevitably they will fail faster.
Unfortunately, I don't think Tesla designed the car with the thought that it would be a Track Car. The tiny radiator is proof of that. I think Track Mode was kind of an afterthought. And it does work really well for 8-10 minutes. It just doesn't work well for a long period of time.
I don't think an aftermarket solution will reduce the lifespan of the components. We're not trying to trick or override any sensors, we're just trying to lengthen the time it takes before the components reach their mechanical limits and are electronically limited. If anything, this should prolong the life of these components (drive units, batteries).
This is also not terribly uncommon. There's plenty of examples of production cars that overheat or limp on track within minutes.
