So the oil cooler hasn't made much difference then?Eh? Now you're speaking my language. Sasha is playing it close to the chest right now, so I apologize for teasing you guys.
It certainly did make a differenceSo the oil cooler hasn't made much difference then?![]()
Source of info?Turns out both - front and rear needs cooling. But large oil cooler is going to disrupt battery warmup that happens at winter, before and during charge and top-up. And SMT oil temps is a confirmed BS. Don't know what is it, but it's not that. Clean solution is larger radiator and both heat exchangers.
Take it to an alignment shop. Best to get the whole thing checked anyway once you've bolted on new suspension parts.Any suggestions here on how to adjust the tierods with the MPP arms? To return toe to nominal after dropping in shims.
not comfortable doing it with just a jack, but don't have access to a lift. Don't think I can really fit in with the car not in the air.
Buy your own alignment tools.Take it to an alignment shop. Best to get the whole thing checked anyway once you've bolted on new suspension parts.
But still no hard data from PP, UP or anyone...Our tests and research.
Definitely need to take it to an alignment shop.
Not really. But if you think that, carry on.that's the great thing about the MPP corkscrew arm, the shims are repeatable enough where you can just align the marks on the tierods and get toe close enough between events to not need a full alignment everytime.
You can do it enough to drive home, though.Not really. But if you think that, carry on.
Not sure what you call hard data. We put temp sensors in both drive units and run it on a dyno 85-30% battery without ventilation.But still no hard data from PP, UP or anyone...![]()
Yes agreed but it's not repeatable enough to do it several times.You can do it enough to drive home, though.
What you did, what you measured, what the numbers were, what you concluded... All hard data.Not sure what you call hard data.
I think that the whole story of racing aftermarket for Tesla is in the very beginning. It will take a time to do good mass market product for anyone. Once I will have a diy solution - I will post a data before and after. Right now I've posted conclusions only.What you did, what you measured, what the numbers were, what you concluded... All hard data.
A lot of us here are interested in this subject but there's a shortage of actual data. MPP promised it, but they are "keeping it close to thier chest".
You have some measurements but all you are showing us is some dyno graphs.
I'm being deliberately provocative of course, but I see no detail from anyone. Someone maybe thinks they want to be first to market with a solution, but I think we're some way from that.
