Realistically it should just be a matter of hooking the headlights up and changing the gateway config. Same way they do the retrofits on the model 3, except the S needs the headlight connector itself changed. Wouldn’t be doable on pre refresh cars.
Your exactly correctRealistically it should just be a matter of hooking the headlights up and changing the gateway config. Same way they do the retrofits on the model 3, except the S needs the headlight connector itself changed. Wouldn’t be doable on pre refresh cars.
Correct. The hard part is getting the change made to the gateway config. Tesla won't do it and the techs I have talked to about it are afraid that config change is being watched and they don't want to lose their jobs over it.Realistically it should just be a matter of hooking the headlights up and changing the gateway config. Same way they do the retrofits on the model 3, except the S needs the headlight connector itself changed. Wouldn’t be doable on pre refresh cars.
Are these shipping yet ?Ordered the AlphaRex's today for my 2016 S, will let you know how long it takes, I got them from @TSportline but you can order direct from AlphaRex too. Weird that TSportline didnt ask if my S was a 2016... AlphaRex is claiming you need converters (a $95 option) on 2016+. I probably need to call them...
AlphaRex NOVA-Series 5x LED Projector Headlights for Tesla Model S (2012-2020)
The new 2012-2020 Tesla Model S AlphaRex NOVA-Series 5x LED Headlights not only improve the look of your Tesla, but increase the performance. Designed exclusively for the Gen1 Model S from 2012-2020, the AlphaRex NOVA-Series 5x LED Headlights are a direct plug and play replacement for your OEM...tsportline.com
Awesome, I'll be paying attention. Good luck!Ordered the AlphaRex's today for my 2016 S, will let you know how long it takes, I got them from @TSportline but you can order direct from AlphaRex too. Weird that TSportline didnt ask if my S was a 2016... AlphaRex is claiming you need converters (a $95 option) on 2016+. I probably need to call them...
Location?Hello to all. OK so I have been in contact with original OP And he has helped me tremendously to say the least! Somebody to change the config on my car for this exact same thing. I bought the swivel screen mechanism, left body control module, matrix headlights, and harness adapter. I made somebody to get in and config those parts and I’d also like someone to change my caliper color to red interior carbon fiber decor instead of wood as I have since changed it. Anyone here can help me with the config? my car is a 2021 but the MCU has been updated and I have the ethernet port thanks!
Thanks for such a fast response man. I’m hoping this works…Disclaimer... you'd be the first person to get this to work on the Pre-refresh cars.
The 2022 Matrix lights only use Power, Ground, and LIN. On the refresh cars there are only 4 pins, one of them is the turn signal hardwired light which is dropped and passes over the LIN pin on the Matrix lights. You shouldn't combine pins. Just drop them and pass the 3 needed through.
The AMP Connector for the Matrix lights is: Power is Pin 1, LIN is Pin 2, Ground is Pin 3.
Look at the 2021 Refresh headlight schematic (SOP14) and the 2022 Refresh headlight schematic(SOP15) to get an idea of what you need to translate.
*Edit* Looking at the picture above the correct PIN positions used in the refresh cars are there in the your connector, for Refresh cars the 14 pin connectors are: PIN 1 is LIN, PIN 6 is Power, PIN 9 is Ground
You need to verify that is the same of the 2016.5 cars. It looks like it is, but you should check the schematic.
can you confirm this as in you have gone in to the gateway config to view if the option is there? i have 24h access to toolbox and would want to avoid paying a day to find out its really not there.I don’t think it’s possible on pre-2021 cars. There’s no gateway config item for global headlamps on those.
I do have toolbox, but don’t currently have access to a pre refresh car. From what I can see digging through the JavaScript, the headlamp configuration is editable, but there’s no global headlamp config for the headlamp parameter on pre-refresh cars.can you confirm this as in you have gone in to the gateway config to view if the option is there? i have 24h access to toolbox and would want to avoid paying a day to find out its really not there.
