Until I see the log it didn't happen.
Interesting.
Maybe this was the "special sauce" that one guy was carrying on about a couple of months ago.
It's also a March P90DL. We should consider the possibility that the battery has changed since the 90 was first introduced. Could the very latest 90s really be P100DLs???
But that would mean that early P90D owners would have gotten shortchanged.
Well this thread is about to explode. The highest recorded for either P90DL or P85DL was 456KW. 494KW is *another* 50 hp.
Can you please post the log file??????
Did you just get a recent software update?
Ok. I think the is what you guys want. At the end of this log file, I did a 0-60 launch.
https://dl.dropboxusercontent.com/u/64789559/RunLog 20160528 210255.csv
Holy Cow! How are you getting all that extra power. I see you have a 2016 P90D. Maybe you have a newer version software which allows the higher current. Can you tell us what version you are running?
When that log was taken, I was running 2.20.30.
Tonight I did it again, this time 2.24.30 and had a peak power output of 501kw doing a 0-60 launch.
Thanks for the update. I updated the chart to show your results. It might help you understand why everyone is so excited since your P90D is showing as much improvement in power as the Ludicrous did to Insane mode. It might qualify for "Plaid":
It will be most interesting to see if anyone else can show that level of performance. Perhaps one of the software updates makes the MaxBattPwr setting more effective and we've all just missed it. One more question: I noticed in your latest log file that the SOC went from 99 to 100% right before you launched. Did you have access to a charger just before doing the 0-60 run?
How do you account for the EPA rated range increase from 2015 to 2016 or is this only true on non performance models? I've always thought they used the same battery in both.Yes. I came right off the charger and did the launch about a mile away. However, I think what you're seeing is regen. If you look at the power, I'm pulling in a negative kw from regen as the car is going down a hill (I also lose about 50 ft in elevation). Right at the bottom of the hill, I come to a full stop and then do the launch.
I think the increase in power happened at some software release that we missed recently. I'm not convinced yet that there is anything different with the hardware of my car vs any older P90DL. Hopefully the data will show that all the lines can move up and enjoy a boost in power and performance.
No, the EPA rating occurred long before the refresh. The only thing I can think of is a change in hardware (e.g. battery, BMS).aerodynamics due to the nose and change in base wheels.
