Michelin Pilot Sport PS2 vs Pilot Super Sport - Opinions Please
Discussion in 'Model S: Driving Dynamics' started by Dreamin, Aug 31, 2013.
  1. Dreamin
    Dreamin Member
    SoCal
    I'm going to dump my Goodyears and go with one of these two in a 255/45/19 (neither comes in a 245/45/19).
    Does anyone have experience with both? I've owned the PS2 and the Pilot Sport Cup (R-compound), but not the Super Sport. Is the Super Sport supposed to be a more aggressive / stickier tire?
    The Michelin marketing machine would have you believe the Super Sport is superior to the PS2 in every way - better handling, longer life, more comfortable...which would seem to defy the laws of physics!
    Thoughts?
  2. jerry33
    Texas
    Generally what that means is that they have developed a new compound and/or construction method. It's actually common for newer tires to beat older tires in most or all categories.
    However, if I were to install these tires I would also get different wheels because the 8.0 inch rim width is the lowest possible acceptable rim width. This means that you won't damage the tires using 8.0" rim width but you likely won't get optimum performance either. I'd go for 9.0" wheels. Worst case would be that they wouldn't perform as well (on the OE wheels) as the Pilot Sport 3 in the OE size. (Note: no actual experience on either so I don't know if they will perform as a worst case, just something to consider before you spend the money.)
    Also note that the wider tire will reduce range and increase susceptibility to hydroplaning.
  3. brianman
    brianman Burrito Founder
    Can you elaborate on this? Thanks.
  4. Dreamin
    Dreamin Member
    SoCal
    Great point. I always try to get tires on the higher end of the wheel width range vs. lower end. But I understand that the PS3 sacrifices dry performance for better wet performance - and being in SoCal:it's always 72deg and never rains!
    The only other summer performance tire on my list would be the Bridgestone SO4 in OE size... vs PS2/PSS 255 on an undersized wheel...
  5. jerry33
    Texas
    Hydroplaning happens when the pressure in the wedge of water that builds up in front of the tire equals or exceeds the tire inflation pressure. The wider the tire--strictly speaking the wider the tread width of the tire--the more water will accumulate in front of the tire and the quicker tire pressure will build up. Tread depth, tread compound, and tread pattern can help but only so much.
    If your tire has a tread width of 200 mm and the water depth is 2 mm, the water displacement is 0.4 m[SUP]3[/SUP] every kilometer per tire (200*2*1000). if you're traveling 100 km/h, each tire has to displace 0.4 m[SUP]3[/SUP] per second (400 Litres or ~106 US gal). (It's convenient that 1 m[SUP]3[/SUP] of water weighs ~1000 kg and a litre of water weighs ~1 kg).
  6. brianman
    Thanks, jerry.
  7. jandkw
    jandkw Member
    Cary, NC
    @Dreamin, take a look at the michelin pilot sport a/s 3. This came out earlier in June this year and has great reviews by the testers. Although this is an A/S tire but it beats some of the competitors' summer performance tires. Just search for the review and there are plenty of them. I plan to replace these tires when my Goodyears reach more miles.
  8. simplesolar
    simplesolar Member
    SoCal
    I believe pilot super sport is the replacement for pilot sport 2. It is stickier, lasts longer, and cheaper. Can't go wrong.
  9. dennis
    dennis P85D
    Silicon Valley CA
    So why is Tesla delivering the P85+ with PS2's instead of Super Sports?
  10. brianman
    #10 brianman, Sep 1, 2013
    Michelin Pilot Super Sport Tire Review RoadandTrack.com - Road & Track
    December 10, 2010
    http://www.motortrend.com/features/performance/1101_testing_the_michelin_pilot_super_sport/viewall.html
    February 07, 2011
    Model S Specs | Tesla Motors
    OEM tires @ TireRack for Tesla Model S Perf 2012:
    OEM tires @ TireRack for Tesla Model S Perf+ 2013 (Rear):
    http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Super+Sport
    245/45ZR19 not present
    245/35ZR21 not present
    265/35ZR21 not present
    I suspect this is your answer, dennis. Michelin doesn't offer Pilot Super Sport in Model S sizes(yet?) -- or at least not without special order or somesuch.
    Kind of sucks because after reading the gushing in the links above, I'm an interested buyer.
  11. Dreamin
    Dreamin Member
    SoCal
    Great information. Thanks brianman.
    LOL. Michelin has a rebate on these tires right now...
  12. brianman
    Wound, meet salt.
  13. mnx
    mnx 2013 P85
    Ancaster, Canada
    255/40/19 have a wider tread than the 255/45/19 in the PSS according to the specs on tirerack. I think I'm going to get them in that size when my Goodyear's are finished. I would consider stock size in the bridgestone S04 but they are quite a bit heavier tire...
  14. gtimbers
    gtimbers Member
    Van Nuys, Ca.
    Look at the Pilot A/S 3. I just got a set (245-45x19) and they kick butt on both the Goodyears (which is easy) and they also easily take the 21" Continentals apart. It is my understanding that they can outperform the PS2's but not the newest Pilot Sports. I have never experienced an All Season that turns, handles and brakes like these tires do. Simply transforms the Tesla into a mean machine. The energy consumption is slightly worse than the Goodyears (maybe 3%) and they do make a slight whirring noise on concrete at freeway speeds - but not too bad considering everything else. They ride very smoothly. Better than the Goodyears and about on par with the continentals.
  15. brianman
    I wonder how they compare for wear. There's been previous discussion about the wear ratings across brands but, for consideration:
    19" Pilot A/S 3: 500 AA A
    19" Eagle RS-A2: 440 A A
    21" ExCont DW: 340 AA A
  16. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I had Michelin Pilot Super Sports on my former G37, and they're great tires. Would definitely recommend them. I am planning to switch when my Continentals wear out.
  17. brianman
    Is Tirerack's data incomplete? I was left with the impression that the PSS aren't available in any of the 3 Model S sizes.
  18. mnx
    mnx 2013 P85
    Ancaster, Canada
    Correct, AFAIK they are not available in any of the 3 Model S sizes.. (I'm assuming Tirerack's data is complete). However, Michelin Pilot SS are available in 255/40R19 and 255/45R19. Both will fit and have the necessary load index rating etc.
    However in the 21" size, I'm not sure PSS is an option. With a quick look all I could find that might work is 255/30/R21 but the load index is only 93...
  19. Doug_G
    Ottawa, Canada
    Tesla told me today that the Contis are worn out. They quoted approximately $2200 for new Contis, installed, and about $3400 for Michelins. Yikes.
    I checked TireRack, but by the time shipping and installation was factored in, the Tesla price wasn't bad.
    Given that they only lasted 15,000 km (not even 10k miles) I couldn't justify the higher price for the Michelins.
    (I guess I shouldn't go drag racing on the next set...)
  20. brianman
    I presume that's Canadian $. What's that in US$ if you happen to know the current exchange rate?
