Have you had time to test it?I don’t know if it going to get as low tonight but I am leaving car outside and will check in morning
It wasn’t cold enough. Will try again later this week as the lows will be around freezing.Have you had time to test it?Interesting to see
If track mode can dump the AC through the battery coolant loop radiator is there any reason they couldn't redirect the cabin heater air through the coolant loops radiator as well? Would be a very large drain to run that wide open when you are driving but seems like something that might make sense when plugged into a supercharger.
if you are interested in tesla's M3 batteries. cooling/heating et al
B Earl, I assumed the heat was coming from the electronics that are part of the battery system/ motor motivation. Not from the cabin heat
The reason that won't work is because the cabin heater is a PTC heating element with no liquid heater core. It's basically a big hair dryer. There is no way to redirect this heat to the battery pack.
The motor(s) are capable of heating the battery pack ... Tesla just has to get more aggressive with their programming. I think they're trying to do as little heat as possible in order to maximize efficiency and range. I expect future software updates will get the heating algorithms dialed in.
Couldn't you just dump it through the radiator? Granted it's highly inefficient but I just meant in scenarios where you are supercharging very slowly due to a cold pack.
inverse of how cool air through a radiator cools the coolant
Turning on the cabin heater does not directly warm the battery, but it does draw current from the battery, indirectly warming the battery pack because of the current draw, but your Tesla can also warm its batteries directly with its battery heater if ambient temperatures are sufficiently cold.Drawing power to heat the cabin also warms the battery right?
Still haven`t heard what regen people actually get when batteryheating stopsJust to summarize what has been discussed in the 3 forum about this as this is the 3 forum. There is no dedicated pack heater and the target battery temp to where an inefficient wave is sent to the motor to produce excess heat, currently, seems fairly low. This has resulted in fairly cold batteries arriving at superchargers.
Still haven`t heard what regen people actually get when batteryheating stopsIn the Model S, I get around 30kW regen and then the batteryheater stops. It would be interesting to see what kind of regen\battery-temp Model 3 has when heating stops
