I'll try to remember itIf you happen to come across any of those links for the math, etc... I'd be interested.
Hmm... Is that correct? I think I remembered that he said that there is no current plans to go above 100kWh. And that it does not fit the Model 3 is of course "with current technology". New chemistry/cell-format may change that.He wrote off 100kWh version for good.
Hmmm... Let's call it 5% then.10% buffer?
None of the cars have had that. It's been more like 3-4%.
Tesla builds compelling, expensive, performance, economy cars. Because of that focus on Performance, the likelihood of drastically low energy use is extremely low. That focus compels people to buy. And people who buy keep the company alive. Survival is the key to longevity. I believe that is the proper strategy for Tesla to employ for the duration. That is why there will not be a Tesla Yaris, Tesla VERSA, or Tesla FIT anytime... SOON, if ever.
Elon has already strongly hinted that there won't be anything cheaper than the Model 3. "A lower cost vehicle than the Model 3 is unlikely to be necessary, because of the third part of the plan described below." From the Master Plan, Part DeuxI disagree. Remember Tesla's mission is to speed the transition to sustainable transport. You don't do that by by leaving out the cheap simple "civic" type vehicles.
First they got to make expensive compelling performance cars. Then they make cheaper cars for everyone. I don't think that stops at the 3 or model Y level.
As Musk said 100kWh is not going to fit, then he said it will not fit when Model 3 arrives, nor few years later.
If he was planning for 85-90kWh then telling "100kWh won't fit" would be incorrect/lie.
Then they will have to rent one from the Tesla Network.I think that demand will drive it. If the three is wildly successful more people will want a Tesla. 35k plus is not affordable for many.
Sample of 1 that says less than 60.
Not enough data for a meaningful conclusion.
A meaningful conclusion is that Tesla will outdo the competition.
Hyundai is apparently claiming 124 miles from a 28kWh battery with the IONIQ.So, expecting Tesla Model ☰ to get an EPA range rating that magically equates to somewhere between 150 Wh/mile and 210 Wh/mile is either woefully naïve or incredibly optimistic, depending on your point of view.
That may be, but Elon's Part Deux plan includes reducing the number of cars on the road (by ride sharing), not making millions of cheap ones.They want to BUY.
And that may well be true but that doesn't mean that everyone that wants one will get one. My son wants a new, super fast, liquid cooled, state of the art gaming computer, he'll get something a lot less expensive and less capable. Since Tesla makes premium vehicles the implication is that they'll leave it to another manufacturer to develop and sell the less expensive BEVs while they continue to push the boundaries.I think that demand will drive it. If the three is wildly successful more people will want a Tesla. 35k plus is not affordable for many.
85-90 kWh < 100 kWh so by definition that wouldn't be a lie.
Again, all batteries for the Model 3 will likely be the same physical size regardless of capacity. Whatever fits with current cooling tech fits. Lower capacities will probably use empties like Model S
We know 100 kWh isn't possible according to Elon. But lets look at the difference between a 70 kWh battery and a 90 kWh battery (20 kWh) using energy density from the Powerpack 2 (130 Wh / kg)
Adding 20 kWh would be (20000/130) = 153.8 kg or around 340 lbs (the weight of two adults). I highly doubt that would drastically affect crash ratings.
Keep in mind in each one of your comparisons you are making it sound like the Model 3 is simply a smaller, less desirable, Model S. Instead, realize that the Model 3 was designed from the ground up with all the knowledge accumulated from the Roadster, Model S, and X. Some of the difficult to change engineering constraints are totally gone. While it may not have as many flashy items as the Model S/X like self presenting door handles, it will be a third generation car therefore has quite a few improvements over Model S/X in addition to being more efficient in everything from the reduced weight, reduced drag coefficient, more efficient inverters, more backseat headroom, etc.
I have a tendency to write really long posts, sorry. Different version (with funny responses here:
Model3OwnersClub )
This time I will shine some light from philosophical way of understanding cars.
Smaller pack has to give out around 215 mile range. 55kWh pack should be appropriate from many angles:
first of all, we all know that Model S came out (initially) with 40 (SF limited), 60 and 85 packs. 40 died immediately.
60 did not die. It is still here. And there is a reason. It is good enough for many. I'm sure Tesla learned that the range
people get from 60kWh pack (now limited to 60kWh, not actually 60kWh) is comfortable for many. Even for rich customers.
To get the same range number (above 200miles in most scenarios) little less is needed for a smaller vehicle.
I read most posts here and here and I'm happy to see my personal estimations coincide. 55kWh marketed number.
This pack would give promised range, even slightly more. Why definitely not 50kWh? Risk of getting "up to 200 mile vehicle" status.
Why definitely not 60kWh? Because this will give much better range than 60kWh Model S. And who want's that?
Should I remind everybody Model 3 audience is for low-mid up to mid-class? As a reservation holder, 55kWh is exactly
what I personally would want. No more and no less (thinking about depreciation).
Ok we now almost know (90-95% probability) that cheapest Model 3 will give out 215-225 miles out of 55kWh marketed pack.
What would be the upgrade option? Again, this time (compared to first link post) let's look at it not as mathematicians.
What are the options for Model S and X? First they had 25kWh upgrade. Considerable amount of range. Now it is 15kWh software,
15kWh physical, and 10kWh more as expensive flagship. Absolute maximum that evolved with years.
Would it be reasonable to offer 10kWh bigger pack? No. It is a small number even for Model3. Price difference is not that noticeable
and same with range. Especially if we start with 55kWh pack. 65kWh is too little.
How about 80kWh? No. Definitely not. It will require lots of space. That means Model 3 will be built around huge pack.
Who will buy 80kWh packs? Model 3 is not designed to be as long-trip friendly as Model S/X. Model 3 is smaller not because
it makes it cheaper to produce but because Model S/X are not appropriate for huge chunk customers around the globe.
Maybe it is hard to understand if you have never lived in heavily populated area in EU or CH or something similar.
Model S is very American vehicle. Big and fluffy. Comfortable to drive. Like a ship. But it doesn't fit into garages, parking spots.
Ideal for wealthier people who have their own garage, their own parking spot at work. Their own private driveway.
So maybe Model 3 should have 3 battery options? 55-65-75 I don't think so. Production should be as efficient as possible.
Vehicle itself must be designed around the biggest pack (weight, dimensions). Why?? Less than 20% buy the biggest pack.
I'm sure biggest battery pack is far from top priority for Model3 overall design.
Also, even with battery prices going down sharply, 80kWh will not be cheap and not light (in 2017-2018).
And lastly, 80kWh might already push the limits of Model 3. Look what happened with Model S. From 85 to 90. From 90 to 100.
I expect little less on Model 3 (optimal pack design from 2017, aka no wasted space). Having 80kWh option in 2017 will be way too early.
How about 75kWh? That is almost awesome. But it is still way too much range. Also problems with vehicle weight, suspension,
tire dimensions. Also having a 80kWh option 2-4 years later will not be spectacular if 75kWh was available from the start.
How about 70kWh? That sounds reasonable. It is 15kWh more. In range it is like 20kWh more on Model S/X.
That is a huge step. In addition, adding front motor with different gearing will extend range even more.
Which might result in Model 3 be advertised as "200-300 mile affordable EV".
This was my guess as soon as I heard "at least 215miles with AWD optional" from Mr Musk.
And lately, somebody saw Model 3 70D. That seems just about right.
But like I mentioned in the other post, 2 different packs doesn't mean only 2 ranges. Due to AWD and rim options there will be more.
All things combined should work in a harmony. Mr Musk (and most of us) agree, that having more and more range doesn't
help a lot. 50-150 miles more range isn't helping if you have lousy charging options while having 1000 mile trip. (khm.khm 50kW)
Model 3, as a vehicle, has more priority in metro-life than Model S/X. It's also true for BMW 3 series compared to 5-7.
This means vehicle overall dimensions are more important than range. Having a vehicle designed for 80kWh pack is
not reasonable, especially if more than 50% of the sales are opting/happy with 200 mile range.
In conclusion.
Model 355 as a base - will kill all Nuts and Bolts.
Model 355D as one of the most loved version in many parts of the world (snow). As a bonus better range than 220mi.
Model 370 - preferred by long distance travelers (or taxi), more frunk space. I personally think this will be rare selection.
Model 370D - ultimate choice for mid-class customers who want excellent performance for less money than Model S60.
Model P370D - the most powerful version. Will require bigger tires in the rear. Expensive.
As a second level prediction I expect model preference distribution something like 25% 35% 10% 20% 10%.
Agreed. It'd be a very stupid business decision not to make a model cheaper than the 3.
But Tesla does not have to be the company to build them. EM has a dream. He does not need to own it. He stepped in because others could not see it! Others will step once the public understands the attraction of EVs. EM may move on.I disagree. Remember Tesla's mission is to speed the transition to sustainable transport. You don't do that by by leaving out the cheap simple "civic" type vehicles.
He MAY move on. I see no reason to believe that Tesla will be some four or five car niche company. Truck, Semi, "civic" type economy car. Why not?But Tesla does not have to be the company to build them. EM has a dream. He does not need to own it. He stepped in because others could not see it! Others will step once the public understands the attraction of EVs. EM may move on.
