Phillyasian
If you check the app after you walk away it will show you whether the car is locked or unlocked.
your absolutely correct. However this is a pain in the ass. I don't want to have to pull my phone out of my pocket, unlock the phone, load up the app (and wait for the car to wake up in some instances), just to see if my car is locked.If you check the app after you walk away it will show you whether the car is locked or unlocked.
True, but that's kind of annoying to do every single time. My Model 3 does lock every time I walk away (as far as I know). But it should work every single time for everyone. There shouldn't be a need for any of us to double check that the car is indeed locked.
Then any thief/joy rider noticing your mirrors aren't folded hops in and drives away. You could see where the car is on your app, but your phone is in the stolen car,,,What if you leave your phone in the car? I tend to do this allot, currently especially if the phone isn't in plain sight.
Agree. I myself nor my spouse have had any problems with phone as key (2 different model android phones)True, but that's kind of annoying to do every single time. My Model 3 does lock every time I walk away (as far as I know). But it should work every single time for everyone. There shouldn't be a need for any of us to double check that the car is indeed locked.
That's not how the 3 works. You don't need to take your phone out of your pocket. Additionally the 3 doesn't unlock until you engage the car door handle.This would really drive me bonkers.
On my Model S I turned off the auto locking/unlocking. I did so partly because I didn't want the car to unlock/lock constantly every time I walked by it in the garage.
I also did so because I like to KNOW it's locked.
But, when/if I get a Model 3 I won't be able to. It's not like I'm going to constantly whip out the phone to lock/unlock it.
if you unlock the car with the key card, it has to be re-locked with the card.
Seriously though. If you unlock the car with the keycard it cannot use the walk away lock feature.
hmm are you sure? I just tested this. Put my phone in airplane mode and left it on my desk. Walked into the garage where I found a locked Model 3. I tap the card to unlock it. I sit down. I get back out and shut the door. I walk away. Car locked by itself.
Hey why not get a notification if you leave the phone in the car.
Oh, wait......
I can confirm that even if you use the card to unlock, once your phone is close enough to the car I'll take over and will auto lock if you walk away.There's definitely something more to it than that, otherwise once it was unlocked with the card-key, it would never re-lock until it had been card-locked.
I don't have consistent access to a 3 to test, but I believe once it sees a phone-key (even if the phone key didn't have to "unlock" it) then walk-away lock is re-enabled.
Example use case: Valet brings car back, having unlocked it with card. You get in and drive home. Having unlocked with card-key, it would not now re-lock -- except (hypothesis) now that it has connected with your phone-key, walk-away is re-enabled.
Make sure you have over heat protection on for your dog.Root cause is obvious: one of the door wasn’t fully closed. I personally always double check whenever I leave my dog (at night only!!) or wallet. Sometimes I just open the app and lock manually.
Tesla designed an unpredictable, semi-reliable means of locking, unlocking and "starting" Model 3. Until they design a predictable, reliable means of doing all these things, the responsibility is yours to make up the difference by whatever means seems to work (for the moment). This is a flaw EM acknowledged and said he would fix, and one that must be fixed before really big numbers of cars enter the fleet.I had to put 'broken into" in quotes because it was as simple as them just opening the door and stealing what was inside because the door was unlocked despite me having auto locking turned on.
Why didn't the car autolock like it was supposed to? I have an Android and it obviously still does not work like it should with this vechile.
