Hey team, have been looking around for the specs of the coolant used in the Model 3. Does anyone know the particulars? Thanks in advance!
I'm guessing that you are not trying to service the battery, so probably you are mistaken about needing this information.
Can't answer the guy's question, so you tell him he shouldn't be asking.
Not exactly a useful response, is it? Just a thought...
I suppose my point was that lots of us come here to learn things because we're curious. I was genuinely curious to know the answer even though I won't need to know for quite awhile now. Lots of us are skeptical of factory maintenance schedules, as well.
Something that's every few months, I could see, but you're skeptical of a maintenance item that has a change interval of about twice per decade?! That's some next level stuff.Lots of us are skeptical of factory maintenance schedules, as well.
Those of you bashing someone wanting to know are probably so academic you don't know what end of a screwdriver does what.
This data should be readily available. Warranty expires, vehicles are salvaged and repaired, heck even just so someone knows what they are cleaning up after an accident or failure causes a spill or leak.
I actually think Tesla has adjusted that interval to "never."
Your Battery coolant does not need to be replaced for the life of your vehicle under most circumstances. Brake fluid should be checked every 2 years, replacing if necessary. Note: Any damage caused by opening the Battery coolant reservoir is excluded from the warranty
So you probably don't need to worry about it unless the car notifies you of an issue (I would assume high battery temperatures during supercharging or hard driving or something) or if you have a leak, in which case you don't want to just dump more in there, you want someone to service it and figure out the problem...
"lifetime" on a lubricating fluid around around moving parts? Well yeah, no one should believe that.Volkswagen advertised many of their automatic transmissions as having "lifetime fluid." It turns out that the transmission completely smoked the fluid after about 100,000 miles, resulting in excessive wear and premature failure. 60,000 mile fluid change intervals extends their service life considerably. I read somewhere that Volkswagen considers a vehicle "lifetime" to be ~120,000 miles. Your mileage may vary.
