acarney
They said the same thing about the engine coolant on recent vehicles. I can find thread after thread on the VW forums about the coolant deteriorating over time, ultimately turning into brown muck. GM had similar issues with Dexcool back in the day.
I always take these "lifetime" recommendations with a grain of salt and do my own research. Trust but verify, although in the case of VW, don't trust.
I would suspect high temperatures would be much harder on coolant then what probably is a fairly "small" working temperature range with the Tesla. I wouldn't think battery temperatures get much above 100 to 120F, even when supercharging (especially when factoring in active cooling with the air conditioner). There are reports from a couple years back of battery temps around 113F while supercharging at ~95kW and the AC not cycling on. 250kW might peak that temp some, but the AC could be turned on to keep it at a manageable level (say 140F or so), and it's a very large mass to heat up and peak supercharging speeds usually don't hold for more then 10 minutes or so.
A car routinely keeps that coolant at near 200F. I'm also not an expert with how the cooling systems on an internal combustion car are built, but there might be more opportunity for contamination to enter the coolant from metal or friction surfaces compared to just circulating though a system that isn't moving or creating friction.
