- “ Frunk “ is extremely hard to close
- Doors do not close effortlessly
- Windshield wipers, on auto, do not come on half the time even in heavy rain. They are not the best wipers even when they do come on.
- Home link opens and closes garage door about 3/5 times I use it.
Frunk and doors and trunk -
The woman who did my delivery of the physical car (not paperwork) did me a great service by demonstrating how to best close the trunk and frunk. Actually, I discovered it works perfectly with the side doors.
In prior cars, and I gather others do this too, give the door a swipe and let momentum do the rest. This works horribly with the model 3.
Trunk, when open, presents a surface at about a 45 deg angle. Place your hands fingers facing each other at maybe 20-35 deg angle and with reasonable force, close the trunk maintaining a constant velocity, not a swipe. That constant velocity will be far less than the swipe. For me and others I've heard from this works consistently and perfectly.
Frunk, pretty much identical. Hands at 35-45 deg fingers facing each other, apply constant velocity for the entire arch of the Frunk (or otherwise hood) travel. Again, this works great although I will admit I generally don't open the hood.
Side doors, closing from outside, same thing, firm pressure/velocity for range of travel. Again, this doesn't have to be fast, certainly slower than a slam/swipe.
Side doors, closing from inside, same thing. Hold the handle and with firm constant velocity, again, not fast or violent, bring the door to you. It'll surprise you how little force is needed but rather than the 'get it started and let go' provide a constant velocity/force from open until latch.
Windshield wipers - yeah, same here. On a day it never rained on auto the wipers came on in the garage. Go figure!. I don't use auto at all. If it's misting a quick push on the left stalk end button will do a single no-water swipe. Otherwise select wiper control, depress intermittent slow, intermittent fast, constant slow or fast.
Wipers are machine learning, I have full faith they will improve.
Home link - for me open on approach, to my recollection pretty much works flawlessly. Close on exit no almost never works. One thing I did when 'programming' it was the car itself was maybe two feet from garage door as I wanted to be between the car and garage so I could point door opener at the sensor to the passenger side of the front logo. The instructions said to bring the car right up to the door. I haven't redone the programming but depending on how you did yours you might consider redoing it. There's a icon on top right of screen in green, depress it and it will show the programmed garage doors, just press the correct one to manually close the door, or open it as it is a toggle not a state machine. In other words if you didn't realize you no longer need the opener that came with the garage opener to actuate the doors.
I hope that helps!
