Note: This feature currently requires accessing the site using the built-in Safari browser.
Thank you.I charged to 309 miles last night and this morning it is showing as 307 miles.Car parked in garage with sentry mode off.Any idea what could be causing the loss of mileage when it is just parked?310 is correct for the LR AWD.
The 348 is the WLTP figure, based on a laboratory style test. You could easily achieve 348 if you drive the car very carefully.
I charged at home for the first time overnight last night.
Set at 90% and it charged to 281 miles, which is consistent with the 310 miles figure total. Which I’m fine with as that is, presumably, a real world figure that I can actually achieve. My assumption when buying the car was that the quoted figure of 348 miles would mean a real world figure of approx 300 miles, so good enough for me.
Sorry i got the miles wrong in my original post.It is 309 miles last night and this morning it showing as 302 miles so lost 7 miles from last night and there is no sentry mode etc1-2 miles is expected especially with changes in temperature
Base it on a rough 3miles per 1% (LR) or 2miles per 1% (SR+), so if you see 50% you know around 150miles (LR).The percentage may be more accurate but I would still need to know the range at the end of the day. Until I figured out the range based on percentage
Sorry
Are you sure that s the right way around? the wltp was meant to give a better estimation of miles compared to nedc
https://www.buyacar.co.uk/cars/economical-cars/907/mpg-meaning-wltp-can-you-trust-the-new-fuel-economy-test
if what you are saying is right hen there's a third test to now take into account and the "supposed to be accurate test" is now just as bad as the old. would the old have given 400 for example?
so now im basically even more confused haha.
would you therefore recommend getting a wifi extender?Sounds like he car wasn't sleeping, for some reason I had this problem when I connected the car to a weak Wifi for the first time, I disconnected the wifi and the car went to sleep.
Perhaps worth signing up to Teslafi trial and you can see if the car is actually asleep or just idle, if its asleep then its shouldn't be using 1-2 miles per hour
I read somewhere (Could be trash?) that the car will workout over time your driving habit/style and the milage you are shown is what the car thinks you will get out of 100% or any % of battery at the time.
Not sure if I can trust the range or do we need to go at 65 on the motorway?
My ICE in the past used to pretend that I had infinite range, and barely drop at all for the first quarter of the tank and then say "Fooled you" for the last quarter and drop like a stone. Energy : Trip doesn't do that, and IME is an extremely useful, and accurate
