So my seat from SIM rig should fit - Sparco Circuit, I wonder if reclining version means just wider base for recliners? @MountainPassAlright guys. MPP has released their seat kit for bucket (reclining version will be out soon).
Anyone going for it? Please post reviews when you have it installed.
Racing Bucket Seat Mount Kit For Tesla Model 3 | MPP.R
Introducing the MPP.R Racing Bucket Seat Mount Kit for Tesla Model 3! No alerts, power sliders, and no compromises - sit low and look good!www.mountainpassperformance.com
I worked together with MPP on this and have been testing the product for well over a year. I've put about 20k miles on it (including One Lap of America).Alright guys. MPP has released their seat kit for bucket (reclining version will be out soon).
Don't forget this is a LHD solution only at the moment. Hopefully RHD coming soon?So here in Oz I think I can get away with fixed back, but must retain a side airbag if I'm to get a mod plate. Does anyone have any experience fitting one of the few seats that comes with an optional airbag? Recaro Sportster is the only thing I've had a look at so far but that's a different kettle of fish.
Separately, how did you find the OMP Champ-R on the highway? Is this a street-legal race car or a legitimate daily use with expected comfort caveats?
So sayeth the product page.Don't forget this is a LHD solution only at the moment. Hopefully RHD coming soon?
Cheers mate, that's helpful info for me to file away.I'm not aware of any besides the Recaro that can retain the side airbag. Maybe someone else is?
Well, I sat in it for over 5,000 miles in 11 days during One Lap. I had to add some foam padding to make it more comfortable for me, but once I got it right it's actually been great. I've since done several ~12 hour long road trips with it since and it's no less comfortable then stock. But, no, I don't daily drive it.
That's just a sim rig brackets I assume. I doubt that regular Sparco brackets would crack like that.I have not actually sat to too many of the reclining racing seat options. However, all the ones I sat in had play in them and I kind of moved past them. Maybe they have gotten better, but if you going for a racing seat, I would recommend a fixed bucket. It will be a lot lighter and more rigid. Just angle them right and they can be very comfortable.
One thing I do want to mention is to make sure you use quality seat mount brackets. I've destroyed a set on my sim rig just braking. I don't want to know what could have happened in a crash, though I guess my harness would have held me in place.
It looks like they are made of aluminum or maybe he has some crazy rig where you have to leg press 200lb to stop the car!That's just a sim rig brackets I assume. I doubt that regular Sparco brackets would crack like that.
Do you know that you don't have to make your brakes so insensitive on a sim, right?
Great feedback. Honestly this doesn’t sound like a solution for everyday use, I think owners would eventually get fed up with the difficult ingress/egress and poor ergonomics.So, I've printed a key and installed the seat.
Few comments about MPP seat brackets:
1. Seat becomes roughly 15cm closer to steering wheel. It's not great, because easy entrance now not so easy as it could have been otherwise.
2. For my seat it ends up 3-4cm higher than stock seat. That is acceptable.
3. Instruction is too short. Some steps are missing, clearly not enough photos. End to end video of the process would save a lot of headache.
4. Because of changes made to the harness, I can't use lumbar function. I could have used it, but power connector for pump was removed and connector for lumbar controller is not at the seat anymore. Honestly, makes no sense to me @MountainPass
5. I assume that I can relocate seat heating, but, again, no cables for it. But I got connector for height motor, which I can't have.
6. Why there is no key for seat belt buckle? It's like few bucks to make it. Also instruction is not mentioning that you need to push side hole together with the key.
Now about usage of Sparco Circuit.
1. It fits in proper driving position.
2. Exiting a car with the seat in easy access position is very hard. Side bolsters are very high. It holds you well, though - much much better than Recaro Sportster. Not even comparable, tbh.
3. I don't see how I can use stock belts properly at all. Still looking for solution. Both buckles are too high and there is no space to put them inside the seat itself. In the meantime, quickfit 4pt belt works, because it buckles in the middle.
4. Head protection is unsafe on the street - I don't see cars. I don't even see front seat passenger. I will cut them.
5. It's a huge contrast in how you feel a car without soft springs in the seat and sliding left to right.
In short. It works. Need to solve safety issues, lumbar and seat heating functions. And need to learn how to exit without swearing.
As per @stevehifi above, good feedback. I'm in a RHD country with strict safety rules so my only practical option is a Recaro Sportster with the airbag correctly connected (plus an engineering mod plate to approve it). I'm hoping that their teased reclining kit will incorporate the feedback that's coming in like yours so I get to enjoy the car on road trips in (nearly) track-ready form (excluding alignment and tyre change). Thanks for sharing.So, I've printed a key and installed the seat.
I think that bucket seats are generally bad idea for mixed usage. I was venturing into that knowingly that it's a bad idea to find out how bad it is and if something can be improved.Dang. I appreciate the effort, but indeed it doesn’t quite seem like we are really close to a daily-able solution.
Still, the Schroth E90 4pts seem to be a solid solution for track stability without much compromise.
