So if there's a power failure there's no way to get into the car? Somehow that doesn't seem right. There has to be a way to get in.
There are several threads about this dating back to 2017/2018. To open the doors from the outside without breaking something in the event of a dead 12 volt battery, you have to pop the frunk with a jump pack on the emergency release wires as described in the owner’s manual, then jump the main 12 volt battery. The car will boot and you can unlock and open the doors normally (keycard or phone key).
So basically, if someone were trapped inside and unable to operate the emergency latch you'd have to call the fire department if you didn't have a jump pack available. This is not good at all. How hard would it have been to provide an emergency entry method that didn't require a jump pack that most ordinary people don't have? (For a car that normally never needs a jump!)
In your scenario, it would functionally be no different than trying to extract an unresponsive person from a locked car with regular, mechanical door handles. You’d have to break a window, Slim Jim or pry the door open.
Indeed - I guess I wasn't clear on that. It just provides access to the main 12 volt battery, which needs to be jumped in order to wake up the car and unlock the doors.By the way, the wire in the tow hook cover simply triggers the hood latch so that you can reconnect or repair the 12V system. It only works if the 12V system is dead/disconnected and only opens the hood by powering the latch directly, not by booting any computers.
Battery life seems to be highly variable but I believe Model 3s are holding up pretty well. Ours is, at least. The car might throw low battery warnings when is time to replace it, or it could be a surprise (hopefully not).I think you were clear. Gauss was a bit more detailed.
How far gone would the 12-v battery have to be for you to be locked out of the car? Or unable to start it once in? And I thought that the computer is always on unless you make it reboot by a confusing procedure with the steering wheel buttons. Do I need to replace the 12-v battery periodically so I don't get locked out?
Here's hoping that he learned about the manual release and has practiced the use of them.It's the front door handle of the 3/Y that you should be concerned about. Even if you knew where the hidden, unmarked manual handle was at some point, you might not remember in a crisis. Fortunately EV's almost never lose power, unlike ICE cars which randomly go dead every few years.
75-year-old gets trapped in a Cadillac XLR, proves you should read the owner's manual
The emergency door release handle doesn't work if you don't know it's therewww.autoweek.com
Ideally the car would notify you of a failing 12V. The 3 seems to have little notice before failing compared to S and X models. For those far from CS or those who want to be proactive, there are options. Some buy a 3rd party battery, from MPP and others, that presumably lasts longer. Some buy a battery test system that connects to the 12V and works with an app on your phone via Bluetooth to log your battery’s health. Others stop by a SC and buy the $85 replacement as a backup, either carrying it around or just replacing the existing one. About 2yrs would be plenty cautious.I think you were clear. Gauss was a bit more detailed.
The 3 still has a 12v battery and a kind of cheap one at that. A bunch of early 3 owners, myself included, had the 12v fail about 2 years in. 12v battery fail = car losing power.Fortunately EV's almost never lose power, unlike ICE cars which randomly go dead every few years.
Out of curiosity have you verified this will pop the frunk? I have heard they do, but never tried it myself.I carry a 9V battery in my pocket
Me, I have a battery tester that I look at once a month; and I carry a 9V battery in my pocket, and have a lithium jump starter in the Frunk.
We've tested and been able to open the frunk with a 9V on a Model Y. It should work on a Model 3 as well.Out of curiosity have you verified this will pop the frunk? I have heard they do, but never tried it myself.
Indeed, when we first got our Model 3 the biggest hassle was warning passengers "The button! The Button! Don't pull up the handle to open the door."I wonder if yours is entirely different than mine. On my Model 3 the manual door latch is right where I would expect the door latch of a normal car to be.
