I would like to see a video/ picture of installation as I am still not sure how it would fit...
Usually it goes between the seal of the car body and the seal of the window frame
but now it would go between the seal of the car and the window glass
or does it clip above the glass? Thanks!
I don't think that the braces will interfere with the top of the windows,
the seal is quite large and there is no door window frame who could touch the braces.
Also, the windows are moving down first for about one inch before you can open the door.
What I more concern with is to determine
where the base of the towers will be laying on the roof,
and in particular if there is
any risk of a possible contact with the glass roof?
Here are the pictures that you can find on Yakima Website.
It seems that there are two ways to set the base of the towers.
1) In the case of the Honda Civic,
the base tower covers both the side and the inside of the car roof frame.
The given references for the compatible covers are
BaseClip 182 (front) and
BaseClip 183 (rear).
2) In the case of the Toyota Prius,
the base tower seems to be away from the roof, witch is
not as stable and sturdy as the previous case.
The given reference for the compatible cover is
BaseClip 117.
In the case of the
Tesla Model 3, the given reference for the compatible cover is
BaseClip 173.
There is no Model 3 pictures available and the BaseClips pictures are all generics and identical for each model,
and there is no detailed dimension information.
When looking at the Model 3 glass roof (see below), I think that
a combination of both types would be preferable.
- I would choose the
"Honda Civic" type for the front tower base, since the gap with the glass roof is wide enough,
because
this solution offers more stability, and the front get most of the wind pressure.
- And I would choose the
"Toyota Prius" type for the rear tower base, because the gap with the glass roof is smaller.
Since there is an REI store next to my home, I will look at the Yakima products and in particular the
BaseClip 173.
I will try to make some measurements or even buy
a set to test the fitting of the base tower near the glass roof,
and to look at the windows area to see how far away the braces will be from the top of the windows.
