Birdsfan
Soft reboot, two steering wheel buttons?It requires a reboot once you select the new wheel setting.
Does it automatically; about 10 seconds after you make your selection from the drop down, the screen goes blank. Back in 17 seconds.Soft reboot, two steering wheel buttons?
Just back from a road trip, probably 1000 miles on the tires now. I’m not sure if they are getting quieter, we’re getting used to them, maybe a bit of both, but I think we’ll keep them. They do him a little still, but finding them better overall. Seeing 285 wh/mi so far after 1000 miles. Previously saw 260 wh/mi over 17000 miles on the OEMs. So a ~10% range hit right now but others report this improving over time.What's the word after more miles? Thinking of going with the AS4s on my new Titan 7s but wouldn't enjoy them being louder than the Pirellis on the Ubers.
245/35/20 won’t rub; it’s the size used on the Zero-G wheels and should work fine. OTOH, 245/45/20 is not going to be mountable due to its diameter causing interference with the top of the knuckle. That one’s a for sure no-go.I have the 2021 M3 Performance w/ the Ubertine wheels. Is it possible to fit 245/45/20 or would that be too off for the computer/ give wrong speeds? I'm looking to go either 245/35/20 or 245/45. I feel like they would both rub on the interior, no? Anyone know how big of a mileage hit it would be for 245/35/20's on PS4S coming from P zeros?
Thanks. That's what I thought. 245/40/20 would be cutting it too close too probably245/35/20 won’t rub; it’s the size used on the Zero-G wheels and should work fine. OTOH, 245/45/20 is not going to be mountable due to its diameter causing interference with the top of the knuckle. That one’s a for sure no-go.
At 27.7” tall, I’d say not that close, meaning it would rub hard on the knuckle as well. If you want to go 245/x/20, then 35 series is your best bet. I’d personally run 255/35/20 on them, that’s the size I’m using with my 20x9.5 wheels, and a 255-width tire fits nicely on a 9” rim.Thanks. That's what I thought. 245/40/20 would be cutting it too close too probably
Can I fit 235 55 20 on my 19’ Tesla model 3 performance? Looking at Michelin crossclimate. They don’t make them in 235 35 20. Thank you.
You should definitely try that. For reference, this is what a 235/35/20 looks like in comparison to a 235/55/20:Can I fit 235 55 20 on my 19’ Tesla model 3 performance? Looking at Michelin crossclimate. They don’t make them in 235 35 20. Thank you.
What size are the Ubertine wheels? 20x9?At 27.7” tall, I’d say not that close, meaning it would rub hard on the knuckle as well. If you want to go 245/x/20, then 35 series is your best bet. I’d personally run 255/35/20 on them, that’s the size I’m using with my 20x9.5 wheels, and a 255-width tire fits nicely on a 9” rim.
Consider the Hankook Ventus S1 evo3. It is a UHP summer tire made specifically the Model 3 19” wheels (hence T0 marked). It is a great compromise for a sporty EV. I’ve put over 11k miles on my set. Relatively quiet and efficient but with high performance tire grip.Looking to replace OE Contis on the 19in wheels with Michelin PS4S, stock size. Problem is there isn't a T0 designated PS4S for the 19 inch wheels. Two variants are available on Tirerack, Porsche N0 and a normal one with no manufacturer designation. Which one would work better on my P3D-? Thanks
Yes, they’re 20x9 ET34.What size are the Ubertine wheels? 20x9?
Probably leaning towards 245/35. Just seems so thin.
