Model 3 Wh/km
Discussion in 'Canada' started by McCaesar, Aug 15, 2018.
  1. McCaesar
    McCaesar Member
    Oakville, Ontario, Canada
    I've had Red for a little over 3 months and 4500 km. Wondering if I'm doing well in performance. Mostly morning commute of 25km each way, sometimes city streets, sometimes 403/QEW
    All time
    4,584km 695 kWh 152 Wh/km
    Today's drive
    13.8km 17 kWh 122 Wh/km
    Is a higher Wh/km better or a lower Wh/km better?
    What are other Model 3s in Canada getting? Any tips to make it better?
  2. Tony_YYZ
    Tony_YYZ Tezler Guru
    Caledon, ON Canada
    lower Wh/km is better. I'll chime in with my lifetime so far when I go back out to the car.
  3. felixculpas
    felixculpas Member
    Ontario, Canada
    Also curious to see what the real time Wh/km numbers are, esp in scenarios where people are commuting on the 403 or 401. Though I suppose that will change a bit with the AWD M3.
  4. TrevTremaine
    TrevTremaine Member
    Toronto, Ontario, Canada
    Wait until wintertime as that tends to sap more energy as the batteries need to be kept warm (there's pack heaters installed). I'm getting around 245 Wh/km on a Model S (lifetime ~ a year and 15K km). That said, I have used things like manually preconditioning (heating/cooling) my car which invariably drives up the energy usage. I also use cabin overheat protection, so on the hot days, again energy usage spikes (I'm still evaluating how much of an impact the window tinting has had on energy consumption during the summer - I'd say it's less simply because the a/c doesn't work nearly as hard). On a good highway stretch I can get somewhere in your ballpark of 150, but never down towards 122. That's the difference between the S and the 3 - lighter weight, smaller cD, smaller motors.
    My suggestion is to review all the settings, especially those convenient ones and decide what you need.
  5. KarenRei
    KarenRei ᴉǝɹuǝɹɐʞ
    Iceland
    That's pretty typical for Model 3; it's much more efficient than the S (let alone the X). What wheels/tires are you on? 18 aeros with caps?
  6. McCaesar
    McCaesar Member
    I have the 19" wheels. I park underground during most days, use Chill mode and lots of regen and AutoPilot whenever I can. Curious to know how that impacts the efficiency along with upcoming winter and cabin overheat protection
  7. zaeem
    zaeem Member
    Toronto
    About 5000km so far. 142 Wh/km, which I think is where you need to be at to get 100% of the projected range.
  8. 5_+JqckQttqck
    5_+JqckQttqck Active Member
    Toronto
    Depending on the trip length, most recent was 113Wh/km, highest 143Wh/km.
  9. TrevTremaine
    TrevTremaine Member
    Parking underground is fine if it's closed and warm - it'll make the battery stay closer to optimal temperature and thusly won't require energy to warm the pack. The issue may be corrosion if there's salt on the roads.
    Chill mode will save energy and full Regen helps (and will also save on brake maintenance).
    Autopilot - unsure. I'd say it's a positive, but traffic flow is probably more of an issue. I don't rightly know if the AP processors and cameras are actively using power at all times but I suspect it does. If nothing else AP is better than driving one's self.
    Cabin Overheat can use up energy as the day gets hotter. If you're parking it in a hot garage during the day, it might be best just to turn it off. Smart Preconditioning - I've not used that because my schedule is always flexible. For those who have strong and stable routines, it might be helpful for getting the cabin comfortable for driving.
  10. KarenRei
    KarenRei ᴉǝɹuǝɹɐʞ
    Iceland
    You're actually doing pretty well for the 19s. :)
  11. oakvillemike
    oakvillemike Member
    Oakville, Ontario
    8900 kms, 142 Wh lifetime
  12. Darscot
    Darscot Member
    BC
    I'm around 9000km and I think 148. I typically have Aeros off but do use them if I'm doing a long drive. I have taken the car for a late night high speed run and that really messes with the average. That kind of driving uses more than double the average.
  13. AFGTA
    AFGTA Member
    Georgetown, Ontario
    I think your numbers are in the ballpark. I'm driving on 18" Aero's with the Aero covers removed.
    My driving is probably 80% highway and 20% city. Daily round trip commute is 160k from Georgetown to Scarborough. My lifetime since delivery June 1 on 8700km is 152 wh/km. City drives are typically in the 120-130 range.
    I use full regen, I don't use chill mode and occasionally let her rip as they say :)
    I dont believe that pre conditioning or cabin overheat useage is taken into consideration on consumption calculations, particularly on the current drive as that is based on mileage and consumption from the time you put the car in drive to the time you put it back in park.
  14. 03DSG
    03DSG Active Member
    Ontario
    #14 03DSG, Aug 15, 2018
    Mine is on the 19” Sports, I don’t hesitate to accelerate :) and I pre-cool the cabin at my wife’s frequent request. Interestingly, to me at least, I have an accurate (+/-1%) kWh tracker on only the EV circuit. The total of that and 2 SC sessions is 815 kWh fed to the car. The 129 kWh difference between fed and used driving can be chalked up to:
    - Me initially playing with car parked in the garage (tell me you didn’t :))
    - Pre-conditioning the AC
    - APP usage and waking up
    -Vampire drain
    Here’s mine since June 5’th
    • Informative x 2
  15. McCaesar
    McCaesar Member
    We're very close. Maybe we're twins?
    Thanks!
  16. Mobsidian
    Mobsidian Member
    Ajax, ON
    Which kWh tracker do you use? Looking for an affordable device to track this.
  17. 03DSG
    03DSG Active Member
    Ontario
    Eyedro wireless. I only have it hooked up at the panel to the EV circuit. One box plugged in at your panel. Second box plugged into your router. Their software takes a bit to figure out but customer support is great! Waterloo based as well.
    Home Electricity Monitors - Eyedro
  18. trevorc
    trevorc Member
    Niagara
    I think I may be the least efficient of the group so far! I’m at 165 Wh/km and I’ve left my Aero covers on since day one. So far I’ve logged 10,200 km including a roadtrip to Tennesee that we just came back from.
    I use Standard regen, but no Chill mode for acceleration. I don’t precondition and I have cabin overheat protection set not to use the AC. My commute is almost 100% highway, half being 400-series and half with an 80 speed limit.
  19. Bandit
    Bandit Member
    Burlington, Ontario, Canada
    Is everyone basically using the trip B computer to track lifetime or is it available elsewhere in the UI? If someone (perhaps another driver) reset it would lifetime stats be forever lost?
  20. Darscot
    Darscot Member
    BC
    I'm using trip B and didn't think of it right away so its off by bit. It should have lifetime somewhere but I don't think it does yet. Hopefully they are tracking it in the software somewhere and can display it.
