@Firehuntah...THANK YOU. That video is why we have this forum. I learned a bunch. I can only hope I can contrite as much someday.
Nice to see the video is already helpful to some. That's why it's indeed always a good thing to share info on forums. You take some and you give some, everyone's happy. I've also learned a lot of things myself through forums.
Something I forgot to mention in this thread but did mention in the other lug stud replacement thread. Some Model 3's seem to have different length wheel studs. I'm assuming European Model 3's as I've seen no one mention any issues so far with the American Model 3's. On my European Model 3 the stock wheel studs were 1.5 mm longer than what someone else measured on their American Model 3. Be aware of this when looking for spacers to use. On my 1.5 mm longer wheel studs I couldn't use the Bloxsport 15 mm bolt on spacers (very popular on this forum) in combination with the aero wheels. This while almost every American Model 3 with spacers is actually using that same exact 15 mm one, at least for the front wheels. So if you want to use 15 mm bolt on spacers with the Aero wheels, first measure your studs to see if it's possible. Do you measure 26.5 mm (brake disc to end point of stud)? Then you can't use them. If you measure ~25 mm or a little bit less then you're good to use them. With other wheels you just have to measure that hollow space inside of the wheel to see if there's enough space for the studs to go into.
