How does Tesla do it? I have read from wikipedia and other source that Tesla does their own Li-ion battery packs, thus this would save them money, whereas most EV converters and major EV manufacturers go to ready-made Li-ion packs that cost a few hundred $$ each. So here is the overview I came up with, how Tesla is doing it. I don't know the exact voltage and AmpHour ratings of the batteries Tesla uses, nor do I know the exact voltage of their electric motor(s), so I will choose one below, that seems workable.
Tesla uses Panasonic 18650 Lithium-Ion
Example Source:
http://www.alibaba.com/product-gs/1308114765/Panasonic_18650_3400mah_lithium_ion_battery.html
$1 per battery
Rated at 3.6 Volts x 3.4 Ah (Ampere Hours) = 12.24 Wh (Watt Hours)
288 volt motor selected for appropriate horsepower, and powered by 85kWh battery system (like Tesla's 85kWh model)
Therefore 85000Wh / 288V = 295Ah (amp hours) rating.
Further, 295Ah / 3.4Ah per battery cell = 86 battery cells to make up a battery "pack" rated at 3.6V and 295Ah.
Further still, to get 288Volts you then need 288V / 3.6V per pack = 80 packs.
Finally 86 battery cells per pack, times 80 packs = 6880 battery cells.
At $1 per battery cell from a good supplier, that is a grand total of $6880 dollars to power the electric motor, and you then need to package
86 battery cells per "pack" (in parallel circuit to get 295Ah per pack) into 80 "packs" (hooked up in series circuit to get 288V).
Now 6,880 battery cells is not exactly the Tesla 7,000 to 7,104 battery cells I've read about, but it is very close, and
describes how I think they are doing it.
Said another way, an EV converter who is able to create his own packs of 86 battery cells per pack, and do 80 total packs, will have
a battery system much like the Tesla battery system, and cost $6,880. Of course you have to make or obtain rectangular
housings for the 86 battery cells per pack, so if you can do that part for one or two thousand dollars, you have a Tesla-like battery system
for under $10k. If you buy ready-made packs for a few hundred each, you would easily get to $20k+.
Then, if you simply do the above steps to create a Nissan Leaf-like battery system at 24kWh, the total cost of batteries comes down
to around $2000. Add some cost to create or buy for cheap the pack housings, and you still don't go above say $4000.
