Model S charge voltage at 100% charge
Discussion in 'Model S: Battery & Charging' started by Matias, Jun 10, 2014.
  1. Matias
    Matias Active Member
    Finland
  2. siai47
    siai47 Member
    Deland, Fl.
    There will probably be a lot of people on this forum that can answer this better but---- When I use a supercharger I see a final voltage of 403 volts displayed on the screen. Assuming there are 96 modules, then it is charging very close to 4.2 volts per cell. My I-MiEV on the other hand charges to no more then 4.1 volts per cell. Chemistries can be different, but as far as most Li-ion cells are concerned, 4.2 volts is usually a "never exceed" voltage. That's why charging to a lower daily charge limit, and storage at a partial charge is beneficial to the life of the battery. With the range of the MS, there is no reason to charge to 100% on a daily basis for most drivers however, to balance the pack, it needs to be done from time to time. This only what I have observed, other observations may vary.
  3. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
  4. tga
    tga Supporting Member
    New Hampshire
    What's the "P120" in your sig?
  5. islandbayy
    Inside joke..... Or is it :)
