Mine did not come with a cable organizer either and I did the new 4.3 update last night and today my charger setting in the car is limited to 60 amps, will not go past the 60 setting and says on the screen, If you have an early version of HPWC limit charging to 60 amps until you get an HPWC upgrade.
You can go back to 80A after dismissing the dialogue box.
. My PoCo charges $34/month for an extra meter. My PoCo is also responsible for the cabling from their transformer to my meter. So if they try to pressure you for an additional meter service, be sure you ask about impact to your bills.
The cable is thick enough that the garage door won't close over it. (Sometimes I leave the car outside when I'm working with tools in the garage).
Nice clean install Mitch.
You mention the cable is thick and the door doesn't close over it. Do you mean the door bounces back up because it thinks it's an obstacle? That's a bad thing, no?
Hi MitchL, what kind of power monitor do you use? I have TED5004 and is max out to monitor 4 breakers. I would like to add two and am shopping for power monitor that won't interfere with the TED. Is yours a Engage? What model?(in case you're wondering, the coils of wires at the bottom run to current sense transformers inside the breaker box. Every circuit has a monitor, or will have, when I finish building the monitor board!)
My HPWC arrived last week. My electrician finally had some free time in the morning and we got it installed. (He tells me all of a sudden he has 6 more to do, so they're definitely shipping).
While larger than the UMC, it's still a pretty small unit.
No cable organizer yet - for now I just coil the wire over the top of the unit.
I haven't changed any settings on the car and so far I'm getting reliable charges at 80A, no breaker trips, error messages, etc.
I ran conduit in the wall during last year's remodel, so the install came out pretty clean!
/Mitch.
Mitch - I'm curious as to what that white oblong object is. Looks like it's plugged into an electrical outlet and phone line.
Had a local electrician install my HPWC w/ a new sub panel. Total cost $940 w/ permit. Had to run cable 50ft from panel and was able to snake it thru the wall so there's no need for ugly conduit. SWEET.
Car is charging at 60A. Hope the upgrade comes soon but after charging at 12A......I'll take 60A.
Wow, this is a good deal. I assume the wires are at least 3awg. Does the $940 includes a 100Amp breaker. Is the new sub panel included in the $940 price?Had a local electrician install my HPWC w/ a new sub panel. Total cost $940 w/ permit. Had to run cable 50ft from panel and was able to snake it thru the wall so there's no need for ugly conduit. SWEET.
What kind of cable?
If it's Romex, like Canadian NMD90, 3 AWG isn't enough for the 100A because Romex must be derated to 60 deg C. Other types of cable (like direct-bury SE cable) aren't suitable/rated for use indoors. Kinda interested in how he did it.
