carrerascott
FUEL FTR
Is anyone still awaiting the HPWC that has already taken possession of his/her Model S? If so, when did you take delivery? I'm trying to gauge the current backlog.
Car delivered March 7, no HPWC yet.
Originally Posted by Lloyd
I just installed my HPWC to a 200 amp subpanel. I am getting a voltage drop (sensed by the car) from 246 to 235 as the current ramps up to 80 amps. Is this much drop normal? I let it run for about 1/2 hour and nothing seems abnormally warm.
I have almost exactly the same setup with the exception of a 200 amp subpanel. I have the same drop almost 246 to 235 v. I asked FlasherZ what he thought of the drop in a pm, and this is his answer so he does not have to post again:
It's tolerable. Usually you try to keep it under 3%, but at 4.5% it's nothing I would worry too much about.
The HPWC uses very premium 105 deg C, #6 wire rated for 80A continuous operation. This generates just over 1% drop across its 25 ft.
The remaining 3% drop could be attributable to a long run from the subpanel. If that's close, then we look at how far your transformer is and what your main service size is (and its cabling). If that's close, then we start looking at the loading on the transformer that would raise its resistance.
Either way, I wouldn't worry at all unless we start to go over 5-6%.
Utility guy's assessment is that I may need a separate meter/feed for the garage. He felt the transformer was very adequate size but that my underground feed wires might be undersized. (I have a large house with two 200A panels and the 125A panel for the garage). He is going to ask the utility company engineers what they think.
Just to share some more from Lloyd's calculation, when I add up the voltage drops for his transformer-to-service-panel, service-panel-to-subpanel, subpanel-to-HPWC, and HPWC-to-car spans, I get exactly (within .1%) what he's seeing. Unless you're seeing voltage sagging below 228V, I wouldn't worry.
Lloyd - can you get the full 80A/20kW charge from your HPWC? Mine always stops at 79A (out of 80) and 18kW. I assumed amps were being limited by the HPWC noticing the voltage drop. 79A@232V is 18.3kW, while 80A@240V would be 19.2kW. Rounding notwithstanding I thought some people had posted photos showing 20kW.
The inside of the HPWC looks so simple. Just like the 75A Open EVSE unit I built.
There really is not much to it. I think the OpenEVSE is on par, if not superior in several aspects.
I received the tracking number for my HPWC. It will be delivered in Anchorage tomorrow (3/29). So, the 48 hour window within vehicle delivery was accurate. I'm surprised. My S is currently cruising (or being barged) home...
07824
