Oooh yay. Hopefully soon!I emailed RPM Tesla and they said they have new mudflaps coming this fall for the new model s!
Awesome!I emailed RPM Tesla and they said they have new mudflaps coming this fall for the new model s!
Hmm... Well, I wonder who knows wtf is up. Mine was from Alexis: "We will be having some mud flaps for the new model s later this fall! Just stay tuned with our social media as that is how we will notify customers."I received an email from RPM Tesla today (Chad) stating 'Currently, I do not believe we are working on mud flaps for the S...'
Look forward to seeing it! What color is your car, again? I’d noticed my MSM MX with ceramic, but without wrap, has held up well against the appearance of chips for 20k miles vs my black Plaid with ceramic only. Wish I’d kept closeup pics of my black 2017 wrapped S—it did get visible pockmarks at a similar mileage point.I’ve got a 1,000 miles on my Plaid that is fully wrapped with XPEL, with countless launches… and so far the PPF on the rear quarter panels are holding up very well with no tears. Will report back after 5k miles.
Nice solution, but I would not want to drill a hole on my LR for rusting problem.A VIABLE SOLUTION - MUD FLAPS
We get almost six months of sand/gravel/salt hell here in Ontario from November until April and I think my new LR will take a crap kicking. I purchased and 'dry fit' a number of generic (and even 2020 MS) flaps and came into a solution that I am confident will do the job. I could not find the manufacturers website but the flaps are made by a company (or branded as) Pro-Fit Splashguards. Everyone sells them and for Canadians....Canadian Tire of course. They are sold by a Model number from #1, #2 etc getting larger and different profiles. I purchased and dry fit #1, #2 and #3 and the #1 matched the front and rear profiles of the body very well. I have looked at a ton of videos on how they are mounted on Model 3's etc and the use of 3M VHB tape seems to be the solution between the flap and the body to seal out crap from getting in between the flaps and the body paint and damaging the paint. That tape is tough yet removeable and is a major part of the mounting solution. As for mounting on the inside of the wheel wells, the front wells have ONE press clip that can be removed and replaced to pin the flap in the place. The lower rocker is plastic so one could drill and use a press clip along the bottom horizontal of the flap. Up top within the wheel well the body panel is metal and nobody will want to drill into that. The flap hangs past the metal and overhangs the plastic wheel well lining that you could easily use a self tapping screw from the flap to the plastic wheel well insert or a press (trim clip). That does the fronts. The rear has no reusable clips like other Tesla models do BUT the body panels are all plastic to drilling a couple of holes and using trim clips (along with 3M VHB tape on the body side between the flap and the paint) will do the trick. The profile and look is custom. They do not hang down too far and due to the design, they profile in with the body very nicely. The mounting is generic and would require removing the rear wheels to have a good access/working platform but I think very simple and doable.
My plan is to move the car into a heated space in early November and remove each wheel to mount the snow tires and while it is off, mount the mud flaps at each location. I cannot find one vendor committing to 2021+ refresh mud flaps and see some are going with the generic flat plastic flaps which do the trick as well however these do give a nice integrated/profiled look so I wanted to get it out there for you.
Is the car aluminum?Nice solution, but I would not want to drill a hole on my LR for rusting problem.
I dont think these fit on the 2021? all the mud flaps I see for prev model s years all say they aren't compatible w/the refreshi have these for my wifes y. I only installed the fronts (backs were not needed) for now and they are very effective at stopping mud, stones, etc from hitting rocker/back door. Plan to get a set for my refresh before it arrives. And super easy to install. No drilling. Look like they belong
4pcs New For Tesla Model S 2014-2021 Car Mud Flaps Splash Guard Fender Mudguard | eBay
Find many great new & used options and get the best deals for 4pcs New For Tesla Model S 2014-2021 Car Mud Flaps Splash Guard Fender Mudguard at the best online prices at eBay! Free shipping for many products!www.ebay.com
Hi there, no holes in steel. Any holes that would be drilled are into plastic parts only.Nice solution, but I would not want to drill a hole on my LR for rusting problem.
I think it is sketchy that they added 2021 on there. The wheel well interiors are different including attachment points. When I look at those, I see an integrated clip at the top that I think would work and then perhaps it is just using the supplied screws into the plastic wheel well liner. I have not found a set yet specifically for the 2021 refresh. That being said, I do believe the geometry of the body panels are the same so the contour of the mats could be a good fit. When I look closer at the eBay pictures, it looks like one of the tabs would pick up one of the trim push pins on the front wells and the rest would be screwed into the plastic well liner. I went to order a pair and they don't ship to Canada so I searched for 2021 specific flaps and lo and beholdI dont think these fit on the 2021? all the mud flaps I see for prev model s years all say they aren't compatible w/the refresh
I do not think this will work on 2021 model S, because RPM emailed back to me with ‘no’ to their mud flaps for 2020 model S.I dont think these fit on the 2021? all the mud flaps I see for prev model s years all say they aren't compatible w/the refresh
Oh…right! I forgot!! ^.*Is the car aluminum?
