Has anyone been able to test against the 5.0 Firmware to see if there are any new fields?
{"charging_state":"Disconnected","charge_limit_soc":90,"charge_limit_soc_std":90,"charge_limit_soc_min":50,"charge_limit_soc_max":100,"charge_to_max_range":false,"battery_heater_on":false,"not_enough_power_to_heat":false,"max_range_charge_counter":0,"fast_charger_present":false,"battery_range":166.23,"est_battery_range":167.7,"ideal_battery_range":191.32,"battery_level":71,"battery_current":-0.6,"charge_energy_added":8.0,"charge_miles_added_rated":26.0,"charge_miles_added_ideal":30.0,"charger_voltage":0,"charger_pilot_current":0,"charger_actual_current":0,"charger_power":0,"time_to_full_charge":null,"charge_rate":0.0,"charge_port_door_open":false,"scheduled_charging_start_time":null,"scheduled_charging_pending":false,"user_charge_enable_request":null,"charge_enable_request":false}
{"df":0,"dr":0,"pf":0,"pr":0,"ft":0,"rt":0,"car_version":"1.35.98","locked":false,"sun_roof_installed":true,"sun_roof_state":"unknown","sun_roof_percent_open":0,"dark_rims":false,"wheel_type":"Base19","has_spoiler":false,"roof_color":"None","perf_config":"Base","exterior_color":"Grey"}
{"inside_temp":54.5,"outside_temp":31.5,"driver_temp_setting":17.0,"passenger_temp_setting":17.0,"is_auto_conditioning_on":false,"is_front_defroster_on":0,"is_rear_defroster_on":false,"fan_status":0}
{"shift_state":null,"speed":null,"latitude":26.407083,"longitude":-80.108949,"heading":173,"gps_as_of":1376935137}
{"gui_distance_units":"mi/hr","gui_temperature_units":"F","gui_charge_rate_units":"mi/hr","gui_24_hour_time":true,"gui_range_display":"Rated"}
