Tesla service is hostile to aftermarket equipment of any kind. Keep in mind if you have USB stuff, or anything plugged into the 12v (cig lighter) port, it goes off when the car goes to sleep, so this will not impact anything in the car. If you have tapped the 12v system so that your device is always on, then that is a different scenario though.
I had a firmware update on my car fail (due to bugs in their system), but they decided to blame it on my dashcam that was hooked to the 12v system. They made me take the car back with old software and remove the dashcam before they would fix the car and apply current software. Total BS, but I had no choice if I wanted to receive updates. Several other owners (without dashcams) on cars with similar configurations to mine also had the same failures and they admitted it was a software issue and apologized. They made me drive to service an additional 2 times for no reason.
- - - Updated - - -
If you get this frequently, disable "energy saving" and check "always connected" and see if the problem goes away. It will use a bit more "vampire" power, but I don't find it to be a problem.
