znino
The problem is that you are searching for locations on Google maps and then it is passing on to a Garmin navigation system. The two systems don't have exactly the same map database so this will continue to happen until they offer to display the Garmin maps on the center screen and search for locations directly in the Garmin system.
That's insane. But in any case if it is Garmins fault it's really bad because I've tried many gps over the years and never seen one not locate my home in a completely wrong place!
I also have not found any place to set a destination by pointing to a map point or anywhere to set a home favorite in the GPS
