Model X 100D Mileage Drop
Discussion in 'Model X: Battery & Charging' started by jackyao, Aug 10, 2018.
  1. jackyao
    jackyao Member
    irvine California
    I had my X 100D delivered end of March, it was charged to 100% at 297 Miles ( did that twice only) and about 265-267 Miles for 90%.
    Once in June I used it till about 15 miles left, and after that when I charged the battery, it only gets to 292 miles to 100% and about 262 for 90%.
    Is that normal? Did it happen because I drove once to very low battery? Any remedy I can do?
    Thanks.
  2. P85_DA
    P85_DA Supporting Member
    Just needs balancing I wouldn’t worry about it much ..just daily charge to 80 or 90 for awhile those “lost miles “ will come back ...;)
  3. jackyao
    jackyao Member
    irvine California
    Yeah, I have been charging to 90% 262 Miles a while... and it's not changed yet, I will wait and see.
  4. rjcbox
    rjcbox Member
    PA, USA
    Probably just needs balancing, wouldn't worry, it'll self-balance over time as you charge and discharge
  5. GazUK67
    GazUK67 Member
    SoCal Inland Empire
    Had mine 18 months and 24,000 miles, and 100 percent charge is down to 281 from 296 when new.
  6. rjcbox
    rjcbox Member
    PA, USA
    Reading hundreds of posts on the same topic over the years, the consensus seems to be these mostly aren't real losses. The car calculates range based on measuring State-Of-Charge and translates this into miles of range left. When cars are routinely cycled as daily-drivers, range-used may only fluctuate 10 or 20% (ex you charge to 90% when you leave each morning and plug back in at night w/ 70% SOC. For some reason this causes the computer to slightly miscalculate the true battery's potential. Some have suggested that a couple deep discharges, followed by full charges will "rebalance" the pack. N=1, but when all was said and done (and balanced), my Model S 70D probably really only lost 4-5 miles of range, or <2%, over 3 years and 36,000 miles. This extremely low range loss over time & mileage is consistent with what many others have reported.
  7. jackyao
    jackyao Member
    irvine California
    Thank you guys!
  8. chillaban
    chillaban Active Member
    Bay Area
    Yeah most likely your first drive down to 15% just improved the accuracy of the charge estimation. I wouldn’t stress over a couple mile fluctuation and I certainly would not repeatedly charge to 100% in an attempt to “rebalance” and cause more wear to the battery.
  9. tslalrry
    tslalrry Member
    Irvine, CA
    I was seeing around 9.3% loss from a 100% of 237 (MX 75D, December 2016, 14,500 miles) to, after a deep discharge and full charge to 100%, 220 miles(!). I noticed a significant drop in range after the SC left it at <10% for two days during its annual service last year, dropping it to near-zero for a number of hours. The SC did a diagnostic and said the cells were fine. Does this mean:
    1. To re-balance, I need to do more deep discharges because one is not enough, or
    2. The SC may have caused real range loss, regardless of what they say about the diagnostics.
    Thanks for your advice. Getting clear guidance from Tesla on this is frustrating.
  10. Nrazar
    Nrazar Member
    Sunnyvale
    How can the SC say that is ok? Beyond me
  11. tslalrry
    tslalrry Member
    Irvine, CA
    That's what worries me...
  12. mknox
    mknox Well-Known Member
    Toronto, ON
    I came to realize long ago that calibrating the "fuel gauge" in distance units is crazy. I just set it to % and relax. If I need to see how far I can really go, I use the car's Energy App which is much more accurate anyway,
    • Helpful x 2
  13. Rocky_H
    Rocky_H Active Member
    Boise, ID
    I strongly disagree, but I would say it works for some people, and it doesn't for other people, depending on how obsessive and stressed each person's personality is.
    Some people are ultra paranoid and are giving themselves ulcers if they see it deviate by any amount. Your advice is good for them, because seeing the miles is driving them insane, so just take that away so they are not seeing that number to set off their OCD.
    But for people who are more calm, your advice to "just set it to % and relax" is bad, because we're not worried or freaking out or going hysterical over little fluctuations in the number of miles, and it's kind of informative. That would not be "relaxing" at all to switch to % and then not have the information on the distance remaining. People think of how far apart things are and how far they have to drive in miles, not percents. Then it's just causing confusion and stress of wondering and not having the information. A lot of people see the display say 226, and think, "Eh, it's ballpark high, so I can probably do about 190 to 200.", and they're not bothered at all.
  14. Nrazar
    Nrazar Member
    Sunnyvale
    Exactly. I am baffled there is no option to set the battery in terms of the "Energy App's" estimated range from your previous driving habits / 30 miles.
  15. Rocky_H
    Boise, ID
    Well, because it's a fuel gauge--not a trip estimator. You don't necessarily want your fuel gauge moving up and down like that.
  16. tpham07
    tpham07 Active Member
    Rhode Island
    Notmal
  17. Electric700
    Electric700 Active Member
    Florida, United States
    So you may actually have about a 7% range loss (237 miles * 93% = 220 miles maximum range). Some people are seeing a 2% to 5% loss after 1 - 2 years, with the rate of loss virtually halting after year two, so yours is almost in that area. I generally charge to 100% to be sure the battery is balanced once a year and after the charge completes, drive it right away. I try to keep it higher than a 10% charge state.
    I also recommend you charge normally up to 90% for better battery health, and make sure Range Mode is disabled since the battery may not be cooled as well with that setting active.
    You're using Rated Range?
  18. mknox
    Toronto, ON
    Sorry if I came off a bit uppity.
    Here is where I'm coming from with that comment:
    The Tesla battery gauge, when set to distance units, does not show "predicted" range as many other EVs do. It simply calibrates the gauge to the maximum distance per EPA rating and, over time as the battery degrades, it reduces that maximum "at 100%" number down accordingly. Then, as you drive, it just decreases in a linear fashion.
    I never drove an ICE car that had it's gas gauge calibrated in distance units, although it would have been easy to do... just take the car's combined EPA MPG number times the fuel tank capacity.
    Neither the ICE or Tesla scenario above is very useful as you rarely get EPA rated efficiency with so many factors at play. In the case of my Tesla, since it is just a linear representation of remaining battery capacity, I would rather have my "fuel gauge" calibrated from 0 to 100 as opposed to 0 to 265.
    Tesla does have a very good Energy App which shows you real, predicted values. I wish that number would show on the center dash with the Energy App widget like it does on the full Energy screen on the 17" panel. That is what I use if I want to know how far I can really go.
    I find it much less stressful than worrying about a mile or two lost hear and there on the dash as I charge to 90%, 100% etc. All I need to know is "how full" the battery is. If I am concerned, what I do is set the Nav to plot a course to my destination, and open the Energy App. As long as my "predicated" miles are greater than my "actual" miles to destination, I know I am good to go.
  19. Jonathantuba
    Jonathantuba Member
    UK
    My 2 months old Model X 100D has shown 252 miles charged to 90% and 280 miles charged to 100% from day one. No change after 5,000 miles of driving.
    The lowest I have let the car get is 14% charge for my peace of mind.
  20. Rocky_H
    Boise, ID
    Your phrasing right here shows the difference in thinking, though. You say it is not "useful", since it will not precisely match the EPA number, so it should just be thrown out and ignored, since it can't be trusted to be exact.
    For most people like me, who are less uptight, that number is still useful and informative, even if it doesn't match exactly. We're OK with seeing the number of "rated miles", and just knowing that we'll probably get a little bit less than it says.
    The % would just show me whether it's less than half or more than half, but what can I do with that so-called information? Without going through some math calculations to try to convert it into some distance, it can't really be used for much.
    So it's the difference between:
    Distance: informative but not precise
    Percent: precise but not informative
