Model X has single 72A charger
ohmman
Upright Member
Global Moderator
Feb 13, 2014
11,546
23,051
North Bay/Truckee, CA
Today, I received information from a Tesla source that there will be a single charger offered on the X, and that it will be a 60A charger instead of 40A. I was told that this was in part due to the fact that getting a charger in the back of the vehicle was difficult due to the 3rd row seating. I'm assuming it is also a nice compromise between 40A and 80A.
Just a rumor, but I have reason to believe this is valid information.
On-board chargers are rated in kW not amps. The Model S charger is 10kW and can accept a current up to 40A; 20kW capable twin chargers double the capacity I.e. Can handle up to 80A at the correct voltage and frequency. While it's quite possible that Tesla has come up with a single charger that has increased capacity above the current 10kW spec, it would also be very unusual for anyone at Tesla to refer to them by amps and not kW.
This is a fair point. In the defense of the source, he was discussing it in terms of my HPWC, which I'd mentioned I used at 80A. And I can guarantee it was someone at Tesla.. not sure if you're implying otherwise but I'm not interested in starting an unfounded rumor.. :smile:
I take your word for it. I talked last week to a group of 3 Tesla sales guys I know, they told me stuff has been kept top secret and they literally had nothing to share even if they wanted to; there are, of course, internal rumors here and there but funnily enough they did indicate that the most interesting rumors were to be found on TMC.
Bearing in mind an increased battery size, slower charging (vs MS spec twin chargers) on all those destination HPWCs doesn't sound too attractive. Perhaps I'm an exception but I really like the relatively fast charge I can get via my HPWC on a 100A circuit in my own garage.
Seems very un-Tesla if you ask me. I mean, aren't they all about overcoming these technical hurdles? Also, it doesn't make much sense: it's too much for a NEMA 14-50 and not enough to make the high power connector worth the extra cost.
Its not going to be a surprise for sure. I believe several people have stated here before not to buy the HPWC in preparation for the Model X as it may be different.
Assuming that the new charger is 15kW, that would mean 6 hours to charge a 90kWh battery from 0-100% or 7 hours if we get the speculated 110kWh battery. That's should still cover 100% of daily usage scenarios. The biggest negative that I can see is slow destination charging. Assuming that Model X has a higher power consumption per mile, then the slower charge rate is compounded by less efficiency to reduce the miles per hour of charge that can be attained.
I have no idea if this is accurate. I guess most of us would hope it is not, if revised chargers really would only reach 75% of current performance. But our (or even Tesla's) wishes may not always be the deciding factor if technical realities dictate otherwise.
I guess the only notion I can offer is that few of the anonymous or otherwise sources (or alleged sources) on TMC have referred to Tesla starting Model X training. If so, I guess it is at least possible more than select people at Tesla having heard such details.
Anyway, I agree such a decrease in home charging potential seems unlikely and I hope there is some other explanation for this rumor.
The performance of the onboard charger need to be upgraded with a growing capacity of the battery.
In my country we have a good reserve for AC-Charging: I can use up to 43kW AC-Power via my standard three-phase-grid at home. We have 63 Ampere on three phases and the Mennekes-charging connector can handle this charging rate.
I hope for an upgrade of the onboard-charger from 32A to 40-50A for three-phases-charging =>no problem to charge a 120-150 kWh-battery overnight.
With bigger batteries, the need for faster charging *decreases*.
I've already installed a 16A 230V (3.6 kW) socket in my garage for the Model X, because I really don't need more than that. The battery easily covers a week worth of driving, and if I return from a long trip with an empty battery, 8 hours of charging replenishes more than enough range for the following day.
On the other hand, if I had a Leaf or something similar, I would find myself in situations where I would return home from a trip in the middle of the day with close to zero range, and then need 100 km a couple of hours later in the evening. Then I'd need ~10 kW charging, so that I could make that evening trip. (Without using a rapid charger.) The Model X covers that use case with no additional charging.
I think the rumor could be accurate, though. I've been suspecting the charger could be getting an upgrade, after the dual charger stopped being available in the design studio. It's apparent the dual charger isn't something Tesla wants to sell, so they are likely to replace it with something better.
This would actually make sense as photos have been taken of a Gen2 charger which is used by Tesla in the latest supercharger systems. This has a 45A battery output vs 30A. However that is only 48A input from 3ph. Maybe 60A over 1ph?
Would not be surprised if Tesla do this for Model S, too.
I am no electrician so a genuine question: Could an upgraded "60A" (to use the term of the thread) single charger be more likely to allow better three-phase Mennekes charging than the current dual setup? Or could either do it but just currently aren't specced up to it for other reasons?
Because that would certainly help in Europe.
- - - Updated - - -
Good point. Thank you.
- - - Updated - - -
A good post. And a related-to-thread image too. :) This conversation is washing away many a disappointments.
No, it's not unusual. Tesla's website refers to them as 40A and 80A in some places.
Source: Tesla Charging | Tesla Motors
That not a reference to to the chargers but to the maximum incoming amps as part of the calculation. Take a look at the specs, or just about everywhere else and you'll see them correctly as kW. I'm not saying this development is impossible, just that it is an unusual way to refer to it.
- - - Updated - - -
6 or 7 hours of charging at home is unacceptably long. With two Tesla's in our garage I stagger the charge start times for conservative safety reasons;; it becomes very difficult, if not impossible, to do this if the X is going to take up so much charge time.
Like many other folks I've wired my garaged with 50A 14-50s and a 100A HPWC. It would be crazy if Tesla now changed to something different that can't optimize usage of existing set-ups.
