.Are you charging on a 14-50 outlet?? Don’t buy cheap. Get high quality UL approved outlets made for hours of continuous full load.
When you say over heat, what are your symptoms. It feels hot to the touch? It is melting the outlet or mobile cable? The circuit breaker trips?
If it is wired correctly, you shouldn't have any of those conditions. You need a 60 amp breaker, 6 gauge wire, and an outlet that is rated at minimum 50 amps. The wiring could be bad as well at the outlet if everything meets stated specs.
The outlet and the Tesla charger gets hot and the charger has letters on the charger and the t flashes red and the rest green
Thanks, I got the wire and breaker mixed.Above poster mentioned 60a breaker that is incorrect for 14-50 max is 50a breaker
I have a 30A breakerWhat is the rest of your setup ? Breaker size ? Wires ??? Someone mentioned 60a breaker that is incorrect for 14-50 ...max is 50a breaker
Yes it feels warm and i get the one flash red and to be honest i don’t know what generation lol i got my model x 2 months ago so I’m not sureThe Tesla charger shouldn't over heat. But, it will feel warm to med hot to the touch at max amperage.
Do you have a gen 2 or gen 1 mobile charger?
Here is a pic of the LED troubleshooting guide for the gen 2.
Ahhh. You should reduce the amps in the vehicle to under 24. The Gen 2 mobile charger is rated at 32 amps which is higher than your rated breaker. Which I would assume is higher than your rated wiring.I have a 30A breaker
You would have a gen2. When you are plugged in, look inside the vehicle charging screen. It will pop up when you plug in. Reduce the amperage to 20 to be safe. That should take care of that. You breaker and probably wiring is rated lower than the charger and vehicle amperage. So, you are overheating.Yes it feels warm and i get the one flash red and to be honest i don’t know what generation lol i got my model x 2 months ago so I’m not sure
Oh okay i see now thanks !Ahhh. You should reduce the amps in the vehicle to under 24. The Gen 2 mobile charger is rated at 32 amps which is higher than your rated breaker. Which I would assume is higher than your rated wiring.
Lol yes i don’t know nothing about electricitySeriously ur electrician put a 30a breaker on a 14-50 plug? ..I assume if he did that he prob put 8gauge or higher wires..u need new electrician and setup
