The car reports 240V so L1-L2 are fine.
Neutral isn't used.
UMC thinks ground is OK.
Hardware works fine on 120V which uses the sane power wires.
14-50 also fails at Tesla.
Adapter is passive pass-through as regards power connections.
Agree about the neutral. But, in the interests of chasing things down and looking at possibilities, I wonder about that ground.
Suppose there was a low-impedance connection to one of the hots on that ground in the socket. There'd still be 240 VAC across the hots. But.. 120 VAC or 60VAC or something idiotic on the ground pin.. could it blow out a resistor or wire somewhere, leaving the ground, well, kind of floating around?
For that matter.. safety ground goes to ground somewhere. Neutral, not quite. That is, Neutral is
supposed to be connected to the ground/neutral bus bar in the main breaker box. And, if one is in a residential house, that's often the case. An AC voltmeter connected between the neutral pin on a plug and the ground pin usually shows near-zero voltage when there's no load, and a couple of volts of I-R drop when there is a load. One might see this, say, on an unused 120 VAC socket when the other socket has a running vacuum cleaner or light plugged into it.
However, in my years of Just Messing Around, I've checked the voltage between neutral and ground in industrial-style buildings I've inhabited. And, interestingly, while there might be 120 VAC between hot and neutral, there was atypically (to me, anyway) anywhere between 0 and up to 50 VAC between ground and neutral.
And then there's the question about whether the house's grounding is proper. In modern construction there's usually a great big green wire that goes from the main breaker panel's ground/neutral bus bar, outside of the house, and bolted to a 6' copper ground stake that's been pounded into the ground. But I've been in much older houses where said green wire was more-or-less haphazardly attached to a copper cold water pipe.
And then there's been the extraordinary stuff I've run into as part of my work in telecom. The most notable, I suppose, where a really thick "grounding" wire ran from inside of a shielded shack, through a hole in the wall, onto a tray, 50' over to a gol-dang 200' telecom tower, up 70' on the telecom tower, and then firmly attached to one of the galvanized steel uprights. And said telecom tower was the highest thing in the neighborhood, by far, and was subject to
lightning. Uh. No. Even if the base of the tower went to some serious ground stakes. One violates the Faraday Cage approach at one's peril. (I got pictures, even!)
So, I tend to be suspicious of grounds and weird errors. And I've seen enough smoked hardware to be
really suspicious.
