Suggesting a sticky thread of interesting issues that have been encountered with the Model X.
Here's my two:
1. Charge port would not open when I pressed the front of it.
2. Software update failed twice in a row. Service states:
Here's my two:
There is a small "bumper" in the front corner of the charge port. That is where the switch for the press to open function resides. It is adjustable! The car had left factory with the switch turned to the farthest outer adjustment which blocks the switch fron working. The tech twisted this little grey stud and now the port opens when I press it.
The connector on the right falcon door inductive sensor is unplugged and the left falcon door rear pinch strip had a poor connection at the connector. This caused the firmware to fail. Connected both connectors and loaded latest firmware 2.26.150 with no failures.
