The close-up of the spoiler only shows two mounting points, one at each end, but we also saw a central depression in the spoiler-less mule. I thought that would be used for the raising/lowering mechanism, but maybe it has been removed now.
Huh. First time I've seen the rear door handles taped over. Maybe they thought that would fool people?
Also, an array of *six* forward facing cameras at various heights attached on the outside of the body (well, I'm assuming the lower pair have mates on the left side like the top camera does.)
What in the world would those be for? Maybe to evaluate different angles for stereoscopic pothole/speedbump/obstacle detection?
Walter
Also interesting that the (auto raising) spoiler should be raised in city stop and go traffic. In my dad's BMW (also with an auto raising spoiler) it raises and come down automatically at a certain set speed (I don't know which one. 70km/h ?)
The logic being that you don't need downforce at low speed, so lowering the spoiler will reduce drag.
Of course, there is also a knob to raise the spoiler when stopped in order to show off.
I think the Model X tow testing was to actually put that F-150 on the trailer when they got the test siteIs it a bad sign that the MX has to be towed by an F-150? :tongue:
You've seen under the X camo?
Nobody can look at that front and say these are final unaltered production cars with some camo on top.
- - - Updated - - -
Image via video: http://i.imgur.com/zvTOqFk.jpg
Isn't your position that these aren't production cars with some camouflage?
Normally at this stage what you see are polished production cars wrapped with some camo, whereas the front of the X doesn't look anything like a production panel (I don't imagine the production car will have a huge gap at the front of the hood). Nobody can look at that front and say these are final unaltered production cars with some camo on top.
A car this big and heavy doesn't need additional downforce even at speed. It's much likely that the spoiler is somehow there to change the airflow for range; perhaps by disturbing the vacuum created behind such a large vehicle?
Disclaimer: I am not an engineer or a designer.
That would be a knob in the driver's seat? ;-)
Yes, there will be aerodynamic lift in the back. About 30 pounds.Quite possible it get a good downlforce on the front, cause sloop of the hood, then at high speeds you will get a lift in the back.
No. Lift would have to be at least 5x bigger to be noticable.Higher air speed on one side gives a lift, it is quite possible this is enouch to make it miss behave when you driving abow 200km/h.
Yes, more or less. There is also plenty of duct tape and bits that you can call camouflage if you want. It was AnOutsider who made an aethetics call on what's under the camo.
Isn't your position that these aren't production cars with some camouflage? Normally at this stage what you see are polished production cars wrapped with some camo, whereas the front of the X doesn't look anything like a production panel (I don't imagine the production car will have a huge gap at the front of the hood). Nobody can look at that front and say these are final unaltered production cars with some camo on top.
...I've said a number of times that I don't think what we're seeing is the final version, and, as you say, the mules look slapped together. So why take issue with my comment that the mules other manufacturers are running about are more polished? I think I can make a call as to the level of polish based on what we HAVE seen. Missing trim and duct tape does not indicate polish to me. Polish, to me, are the finishing touches (including trim) put on a car.
I am a Naval Architect. Boats through water, planes through the air, or cars over land... its all about friction/drag. As air flows over the vehicle, the longer you can keep that flow "stuck" to the surface of the car/boat/plane, the better. this is called a "boundary layer". When that boundary layer is there and stuck, you have "laminar flow". https://www.grc.nasa.gov/www/k-12/airplane/boundlay.html When the layer breaks down, you get turbulent flow.
All that turbulence is weight being pulled along with the vehicle. This is why hypermiling/drafting works.
In motor sports, they use the spoiler for two reasons, one of which is to increase drag. First is to slow things down and make the cars safer. Much higher speeds than even highway speeds. The other reason is to avoid a wing shape at the rear of the car. The car (NASCAR) looks and acts like a wing at high speed, lifting it off the ground slightly. This all the upside down wings in F1, Indy, etc.
Why does a SUV have an adaptive spoiler then ? Wouldn't a spoiler create a turbulent layer and more drag? Yes. The reason for the spoiler is to create a controlled/known turbulent layer that is smaller than what would be created without the spoiler.
Think about the F150 going down the highway. The spoiler is the rear tail gate. Open the gate and NO, you DONT decrease drag. You are now creating a larger turbulent layer. Keep the tailgate closed and the air flows over the front and is trapped by the tailgate. You have a smaller turbulent layer in the truck bed and behind the truck.
