Hi Everyone.
I have a 2020 Model X Performance.
When I hit the brakes at highway speed, the car shakes, which I thought was a brake issue at first (which would have surprised me at such at only 32k miles).
So I took a look at the tires and noticed the inside of my rear tires were down to the steel braids (see pic), and the balance weights were coming off one of the tires. I immediately order rear replacement tires.
This led me to believe the alignment was off so I had a local shop check the alignment (see pic). From the results, nearly everything was in spec, which made me wonder how the inside of the tires were so badly worn. Does anyone have any insight into how all the metrics on the alignment check would have impacted tire wear?
Finally, I asked them to look at the brakes, which I thought was the original issue, and it looked like they were all in spec.
So I assume that once I replace the tire, the shaking should stop - does that make sense, or do you think I need to get it aligned, or there are some other things I should investigate.
Thanks!
Thanks!
