I’ve an early MY in the UK with Ryzen/Li Ion low volt battery.
Tesla Remote Techician mentioned that it would work with an old Lead acid battery. Can anyone confirm that? Reading the ener thread it seems that also has issues!
The M3 has never had anything above pin 8 wired up, so it only runs the essentials and no auxiliaries. The MY has wavered between offering the higher pins and not. At one point the modules they were providing did offer auxiliary switched and live, however the latest modules don’t seem to offer this. The manual even states it may or may not work.
View attachment 966442![]()
Model Y Owner's Manual | Tesla
Learn how to safely use your vehicle to carry accessories and tow a trailer.www.tesla.com
Plenty of us tow caravans with the Model Y and since the switch to using a 16V lithium low voltage battery, there has been no permanent 12V feed to the tow bar electrics.Hello All,
just picked up my MY RWD with Towbar factory fitted, and the electrics don’t work. Tested the connection and it doesn't have a Live feed or a switched live for charging the caraavan fridge etc.
Raised a service request and they very quickly came back with " pins 9-13 aren’t enabled in the new Li-Ion aux battery versions. Tesla are working on a fix but don’t know if it will be HW or SW!"
The reason the pins arent currently enabled is cause they don’t know how the Li-ion battery will react with caravan/trailer electrics and vice versa!
So it seems like an unknown wait period! Considering the reason we leased the car was to two our caravan in the 1st place!
The Lease company is now involved!
This is taken from the current manual and would appear to indiate that there are versions with the Lead Acid battery out there!Whether this is the same with Model Y I do not know. Were Model Y’s ever fitted with MCU2, ie 12v battery? I thought they all came with Ryzen and Li battery.
Manual covers Europe and it launched there about 6 months earlier than we got it before Ryzen and the Li Ion batteryThis is taken from the current manual and would appear to indiate that there are versions with the Lead Acid battery out there!
"Vehicles with a lead-acid low voltage battery have auxiliary power. Vehicles with low voltage lithium-ion batteries do not have auxiliary power at this time. You can determine which battery your vehicle is equipped with by touching Controls > Software > Additional Vehicle Information."
Thanks Qwickshot, is that a simple thing to do? Who would?ATC is slightly different, most owners get it re-wired to be powered off the onboard leisure battery via an on/off switch. The lights all work fine the only thing that doesn’t get powered is the fridge or any ATC type product if you have it installed.
Caravan service technician can do it or DIY, probably the former.Thanks Qwickshot, is that a simple thing to do? Who would?
Have you got an older or newer caravan and has it been modified at all from it’s original specification?Sadly, non of the lights work which makes it illiegal in the UK [ I think!] They are all LED.
If you have some suggestion of what can be done to fool the car I'm all ears!
Thanks in advance.
Pins 1-8 are wired in, which control the lights. So they should be working with the Tesla towing electrics, no matter which revision you have. If your caravan lights aren’t working, you’ll want to make sure things are working on both the car and the caravan.Thanks Qwickshot, is that a simple thing to do? Who would?
Thanks in advance.
