I honestly think if you consider it a 200-250 range car and plan accordingly you’ll be better prepared- that’s my plan.Anyone know if there are tweaks you can make to the driving settings to get more range if doing a long drive??
Prices are up and down like a yo-yo at the moment. I expect used values could increase quite significantly given the recent price rise and long lead time - Feb 23 for a no spec M3!Forgive my ignorance but;
Why would your M3 be getting more valuable the older it gets?![]()
Yes, think you’re right. Need to wipe the idea of a 300 mile range from my memory!I honestly think if you consider it a 200-250 range car and plan accordingly you’ll be better prepared- that’s my plan.
Most important is to pre heat the battery before you leave, do it whilst plugged in so it uses the mains electricity. Also, light acceleration and low top speeds make a big difference, driving near 80mph will give dramatically less range than 70mph.Anyone know if there are tweaks you can make to the driving settings to get more range if doing a long drive??
Only negative is the real range achieved versus the range displayed.
Use ABetterRoutePlanner for your long trip. Choose your car model (it will remember that) and put in Start Location and Destination (which might be back at the start) and all the way-points. ABetterRoutePlanner will tell you where you will need to charge and how long you will have to wait. IME its consumption figures for e.g. motorway are spot onMakes we nervous about when we want to go on a long journey
All good tips, didn’t realise that pre-heating the battery would make a difference. ThanksMost important is to pre heat the battery before you leave, do it whilst plugged in so it uses the mains electricity. Also, light acceleration and low top speeds make a big difference, driving near 80mph will give dramatically less range than 70mph.
Also warm weather makes a big difference, if you do all the above on a summer day I think 300 miles will be possible with this larger battery the Ys now have.
Oh, and put acceleration mode into chill, it will even affect the autopilot acceleration rate.All good tips, didn’t realise that pre-heating the battery would make a difference. Thanks
Again, thank you! Steep learning curve this electric car business. Will read up on this and try abetterrouteplannerMy prediction is you will get used to that. General recommendation is to change to Percentage display instead of miles. I figure to get about 3 miles per Percent (if I need an off-top-of-my-head number to know if I have enough range).
In Winter you will need to CONFIG the expected temperature, allow for Wind, if the road is likely to be wet, and an allowance for weight of passengers and luggage. Wet roads is definitely a consumption problem (only time I have nearly run out was unexpected torrential summer thunderstorms along the whole length of a 100 mile journey), but other than that Temperature makes the most difference, and putting in 5 MPH wind is probably sufficient for general-contingency. I've made that sound more complicated than it actually is in practice.
You can then change if you will depart with 100% from start-location (or any way-point, e.g. overnight stop with charging), and you can require that you arrive with a minimum (e.g. you want to arrive at a stop-over with enough to do some sightseeing / running around.
I recommend using ABetterRoutePlanner to test out known long journeys that you do - visiting Family etc. - so you know what to anticipate - e.g. a 20 minute stop for charging which you wouldn't have done with ICE.
That would also give you some confidence about what the actual "total motorway range is". If you leave at 100% you will want to charge around 10% (30 miles contingency), and that would presume that there is a perfectly placed charging location !! You will then only want to charge up to 80% because above that is much slower. So you initial leg would be 90% range, and each top up after that (on a journey across Europe, for example) would be 70% of range (i.e. charge from 10% to 80%) and be about a 20 minute stop. M3 / MY LR should give you about 250 miles total motorway range, so 70% would be about 2.5 hours driving at 70 MPH, which is a pretty good interval to have a break anyway
ABRP
ABetterRouteplanner is the world's most popular consumer EV routeplanner - both for beginner and experienced EV drivers. And of course for anyone curious about EVs.abetterrouteplanner.com
On a motorways maybe, but on dual carriageways with roundabouts every so often it does.I don't find that makes a noticeable difference, if I'm on the motorway, because the car is "cruising" for the majority of the journey. (I also think its a pity there is no kick-down in Chill mode, because one day I just might need that)
On A-Roads it probably would, but I am rarely on a range-challenged journey on A-Roads, and on days when I'm not range-challenged I'm happy just to press on, and fill back up when I get home.
Let us know how it goes. I'm 1.5 weeks behind you!This time tomorrow we will be in Bluewater to collect our MY![]()
Me too. Was hoping for a magic text saying “surprise, your MY is now ready for collection”. Wishful thinkingLet us know how it goes. I'm 1.5 weeks behind you!
Lol, I had that dream too!Me too. Was hoping for a magic text saying “surprise, your MY is now ready for collection”. Wishful thinking![]()
Long journeys charge every two hoursMy prediction is you will get used to that. General recommendation is to change to Percentage display instead of miles. I figure to get about 3 miles per Percent (if I need an off-top-of-my-head number to know if I have enough range).
ABRP
Good decision just make sure that if you do get bird crap on it make sure you clean it immediately or the seriously fine aspect will be 'seriously flawed'I'm going to save this money by not bothering with any coating or protection. The car is seriously fine as it is.
Why would you buy a second hand for more than new?One of the original ex demo car popped up for sale over night. Not a bargain at just under 60k with nearly 7k miles on it and with probably hundreds having driven it but thought it worth a mention
Will do SparkyLet us know how it goes. I'm 1.5 weeks behind you!
