Well spotted ... no! 5 mins for the cabin, allow 10 mins for the battery pack to warm a bit ... but you really don't need to allow for that at all unless you are desperate for the few miles range this can add. (With expensive peak rate I'm expecting to use very little preconditioning this winter compared to previous. With seat heaters and the rapid heating of the cabin it's hardly necessary unless there's ice all over the car.)This will be my first winter with a tesla does it really take 40 minutes for it to preheat? 🤦♂️ I'll have to check my automation settings in tessie 😆
Like this! All frozen up, even after a long preheatWith seat heaters and the rapid heating of the cabin it's hardly necessary unless there's ice all over the car.)
Bigger...A button to quickly toggle dipped wing mirrors when in reverse
We can already do this - Just select reverse - then go into mirror adjust - select each mirror and adjust to the position you want then press the park button - each time you select reverse the mirrors will go to your reversing settings - and go back to normal when you either park or select forwards. Unless I'm misunderstanding your comment.A button to quickly toggle dipped wing mirrors when in reverse
That isn't a feature of the Model 3&Y, it is only on the Model S&X. (And isn't what they were asking for. They want to be able to quickly flip between the two positions when they have different things they want to check for.)We can already do this - Just select reverse - then go into mirror adjust - select each mirror and adjust to the position you want then press the park button - each time you select reverse the mirrors will go to your reversing settings - and go back to normal when you either park or select forwards. Unless I'm misunderstanding your comment.
Precisely.That isn't a feature of the Model 3&Y, it is only on the Model S&X. (And isn't what they were asking for. They want to be able to quickly flip between the two positions when they have different things they want to check for.)
I find that Gummipfledge (rubber conditioner) or similar on the window rubbers and WD40 in door handles (no more than twice through winter) means that windows and doors open even in freezing conditions... but it will be cosy inside. Preheat will never thaw the outer car surfaces ... it's not like an ICE with copious amounts of heat (eventually) emanating from the engine compartment.Like this! All frozen up, even after a long preheat
Yes the rain/freeze combination seems to be the biggest challenge. It’s a rare event (for me) but I have seen the issues you describe. It’s a design issue that affects cars with frameless windows which need to drop a little to allow the door to open. The door handle “bucket” could perhaps benefit from a drain… but that would probably freeze too! A thump with the heel of my hand on the thick end of the handle has always worked eventually.Gummipfledge works great on the windows outer seals, WD40 great on the spring, but it’s the seal at bottom of window/top of door and the ‘bucket’ that the handles sit in that are the problem, neither of which have any effect on. Water ingresses in those inaccessible areas are freezes everything up solid.
That won’t happen as other items need to be changed to work with the new 16v system.Retrofit for the LI low voltage battery
Damn I was about to get excited.. why isn't this a available on M3?That isn't a feature of the Model 3&Y, it is only on the Model S&X. (And isn't what they were asking for. They want to be able to quickly flip between the two positions when they have different things they want to check for.)
I didn't mean fitting the higher voltage LI battery Tesla now use - What I'd like is for Tesla software to allow us to replace the 12V lead acid with a 12v li battery - like the ohmm battery. Apparently, the car charges the lead acid differently to an LI so the software could be updated to select lead acid / li when it comes to replacement time (owners that fitted the Ohmm ran into issues with them going flat)That won’t happen as other items need to be changed to work with the new 16v system.
The reverse mirror tilting? It is, and always has been. You just can't toggle it whilst driving which is what I believe is being asked for.Damn I was about to get excited.. why isn't this a available on M3?
It took them a while but they still haven’t put in there is how to then open the door because it’s partly opened but the window is still wedged under the trim and won’t drop because it’s stuck solid along the bottom edge of the window/top edge of door.
