Yup they’re all stuck. Maybe there something I’m missing they isn’t the lip or the center bore, but no clueI’m confused. All four are stuck on? That little lip shouldn’t matter too much because the center bore of your wheels should be flared on the end to be hub centric.
Attaching photos. The wheels are sitting flush to the hat. With a heat gun and some elbow grease I got about a mm of wiggle, but the wheel still won’t come off.You won't need to removed the center cap. Look at your wheel, take a photo through the spoke from a foot or so back, facing the center of your brake rotor where the wheel seats to the rotor (hat).
I suspect that you live in an area where road salt / grime has caused the wheels to friction fit. I'd also suspect that the shops you dealt with don't want the liability. Next shop, I'd offer to sign the work order with any sort of 'liability waiver' that the shop is comfortable with.
I assume the wheels you have are meant for all 3's, which would track for cost effective model 3 specific wheels. And your comment about them mounting fine. You'd absolutely know if the wheels were not flush against the brake rotor hat.
To be funny, you could always joke with the workers to "hit it (harder) with their purse (sledge hammer)".
Attaching photos. The wheels are sitting flush to the hat. With a heat gun and some elbow grease I got about a mm of wiggle, but the wheel still won’t come off. View attachment 874126
If you’re able to get any wiggle, keep at it, it will come off.Attaching photos. The wheels are sitting flush to the hat. With a heat gun and some elbow grease I got about a mm of wiggle, but the wheel still won’t come off.
Park next to something you can wrap heavy duty ratchet straps aroundThanks for all of your ideas. I definitely like the idea of the gear puller. I’m not sure the wheels will have best spot to place those hooks, and I’m concerned that the hooks are just going to eat through the rim with them touching such a small surface area of the wheel, though.
Tried loading into a wedge. Tried the gear puller. The wheel doesn’t allow for the best gripping on all 3 hooks, but I got it to grab and cranked an ungodly amount of force and nothing. I have about a mm of space generated, but no matter what or how many times I do it, it just won’t wiggle off. It seems to be completely mechanically seized.There are lots of ideas on YouTube about seized wheels. Putting a solid object as a wedge below the inside edge of a tire and lowering the car onto it, using a tree stump as battling ram, backing off the nuts 1 turn then driving the car a bit with some steering input.
I still like the bearing puller idea the best. If you could move the wheel 1mm then that means you will be able to get it off.
attach hooks on straps to the wheel spokes
undo lug nuts
heat the wheel with heatgun/device you’re comfortable using to shove heat into the hub face
crank the straps until that wheel starts moving.
Really sounds like you’ve got a friction fit due to wheel coating and/or corrosion from winter.
I’ve considered attaching straps to another vehicle and trying to pull. I’m confident at this point that it would just drag the car off the jack. Something has caused it to completely attach. I would say corrosion and winter is possible, but the car has been driven ~50 miles in this condition and we haven’t any snow/salt yet on that roads. And the first time they were stuck had about 10 miles and no weather at all. I think by tightening the lugs the first time, I’ve deformed some metal either in the brake hub or the wheel to become completely attached.
Once you get the wheel off, then treat the rotor hats with Wurth SBS Brake Treatment II SKU # 189311069
"The SBS Brake treatment is a revolutionary spray-on metalizing treatment designed to prevent brake noise at the source. When applied as directed, microfine aluminum products form a molecular bond with the rotor/drum friction surfaces. This composite surface finish ends annoying vibrations and brake squeal at the source, giving the assurance of a quality brake job."
Treats pads and rotors-
-Spray a light mist of SBS Brake Treatment directly to the rotors/drums and pads/shoes
-Effective on all brake systems
-No drying time required
-Benefits last up to 1 year or 10,000 miles
-Prevents rust and seizure of lugs
-Extends brake life
-Effectiveness tested from -100 degrees to 1800 degrees
PRICE-$21.00 and includes shipping
NOT ON WEBSITE, CALL TO ORDER
Phone: 1-800-WURTH-USA (1-800-987-8487)
Email: [email protected]
Wurth USA Inc.
93 Grant Street, Ramsey, NJ 07446
Yup sounds about right. I’m at 10 hours invested at this point and have nothing to show for it. Already had 3 shops try and say sorry no luck. Had 10 others say no way I’ll tryMan I feel so bad for you. I remember how hopeless it felt when my winter wheel seized on and it took me 2 hours to get it off. I can just imagine how you're feeling now trying all kinds of things.
If nothing works, contact body repair shops? They always have solid posts and pulleys for pulling frames straight and should be able to pull on wheels to get them off.
You're right, a big hammer will be able to get it off if it wiggles. Try that or a big piece of wood that gives you more momentum. If it wiggles it'll come off.TBH, I'd be happy the wheels didn't fall off on you while driving on a highway.
IF you have movement, a BFH should help convince the wheel to come off.
My guess is that after these come off you will at the very least need 20 new lug bolts.
I agree that some metal has deformed and I’m trying to brute force it off. I also generally agree with the sentiment that if it wiggles then it came come off, but at this point I have tried sledge hammers, crowbars, the gear puller with a 6 foot breaker and the wheel is not coming off.You're right, a big hammer will be able to get it off if it wiggles. Try that or a big piece of wood that gives you more momentum. If it wiggles it'll come off.
I think the wheels have plastic deformation around the hub and op is literally trying to destroy the deformed metal to get it off.
I'd try to use the bearing puller and then hammer, alternate between the two.
This is the one thing I’m not concerned about even in the slightest. There is nothing unsafe at this point with these wheels on the car. I am fairly confident I could take all the lug nuts off this car and drive on the highway and the wheels wouldn’t budgeTBH, I'd be happy the wheels didn't fall off on you while driving on a highway.
