MPP Comfort Coilover reviews?
Discussion in 'Model 3: Driving Dynamics' started by WhiteStarSal, Dec 19, 2018.
  1. Devin94539
    Devin94539 Member
    SF Bay Area
  2. Devin94539
    Devin94539 Member
    SF Bay Area
    Well, I don't know if I can afford them, but I went ahead and bought the mpp sport coils and rear camber arms . any advice on where to get installed in the bay area?
  3. P-Lo801
    P-Lo801 Member
    Sacramento, CA
    I don't have any personal experience with them, but i've heard nothing but good things about them in terms of workmanship and reasonable pricing: Sonic Motorsport
    I've also read good things about Griffin Motorwerks in Albany/Berkeley area.
  4. EmOne
    EmOne Member
    Chicago
    I'm pretty sure the shocks weren't your problem; it is the very limited range before hitting bump stops.
  5. TLLMRRJ
    TLLMRRJ Active Member
    Houston
    I dunno. I can understand that for lowered cars, but my 3 was jacked up like an SUV on the factory suspension, so it should have had enough travel. It was just an uncomfortable ride with the stock suspension.
  6. MODEL+
    MODEL+ Vendor
    Portland, OR
    Nah, the shock travel is really short in relation to the bump stop. When I was putting on springs I was legit shocked (no pun intended) so I took a pic...
    This is for the factory ride height, think about how much travel you're left with on lowering springs.
    I'm on MPP comforts now, night and day difference even when I'm sitting slammed on 20"!!
  7. Dave EV
    Dave EV Active Member
    San Diego
    You have to keep in mind just how soft and progressive "bump stops" are in your typical OEM setup. They are very typically designed to be on the edge of engagement or very slightly engaged at stock ride heights. Think of them more as secondary, progressive springs than hard bump stops. Most of the harshness in the stock setup is likely due to shock valving and not necessarily due to the bump-stop setup.
    The Bump Stops Here - Tech Talk - Modified Magazine
    Insights into bump-stop tuning | Vehicle Dynamics International
  8. MountainPass
    MountainPass Vendor
    Toronto, Canada
    We calculated the spring rates of the bump stops and springs independently, then combined so you can visualize the difference!
    Suspension Tech - Firmer But More Comfortable? How Can That Be? | Mountain Pass Performance
    • Love x 3
  9. Dave EV
    San Diego
  10. dfwatt
    dfwatt Active Member
    FL
    Don't quote me but I think they got that too. Mountain Pass has just about every base covered.
  11. BlackM3
    BlackM3 Member
    Sherman Oaks, Los Angeles, CA
    2018 Model 3 RWD here with 18s and Pilot Sport 4S tires. I want a much less bumpy ride, willing to sacrifice handling. Can anyone tell me what to get for the best ride quality?
    - Looking at MPP Comfort Adjustable coilovers
    - Would MPP toe arms or camber arms be needed too?
    - What summer tires will be the most comfortable? I'm in Los Angeles.
    I'd like to stay as close to stock ride height as possible. Any info is appreciated, Thanks.
  12. MasterC17
    MasterC17 Active Member
    The Comfort Adjustable Coilovers are great! I just took delivery of a 2021 Performance and forgot how much nicer my 2018 rides on the MPP Comfort's - it's a night and day difference. You would not need the toe arms or camber arms unless you are looking to track the car. You can definitely have them adjusted to the stock ride height. The PS4S is a pretty great summer tire, I would probably stick with that.
  13. Zcd1
    Zcd1 Member
    Chicago area
    If anyone in the Chicago area is running these and would demo them for me, I’d really appreciate that! (if and when it’s safe to do so)
  14. Dave EV
    San Diego
    I guess the question is whether or not the adjustable comforts can let you dial in more comfort with lower damping settings...
    It does look like with the adjustable comforts, the highest ride height is 10mm lower than stock, while the non-adjustable comfort can maintain stock height. In SoCal, does the extra corrosion resistance of the adjustable coilovers help much?
  15. zman222
    zman222 Member
    Long ISland
    The Camber arms are highly recommended. Jesse from MPP, however, stated they are not essential if you are lowering your model 3 about 0.5 inches or less. Your alignment may just be very slightly off if that matters to you. After I had the comfort adjustables installed I immediately noticed greater stability feel and those very harsh bump impacts seemed to disappear. My 2018 LR Dual motor Model 3 with boost now feels like a tight sports sedan without any harsh impacts that make me wonder if a rim just bent. Before the MPP dampers I would occasionally hit a pothole that felt like the car was damaged. In fact I wondered if I should keep the car no matter how amazing the pickup was. Make no mistake, the car is not Camry soft now; it's simply a more refined sports sedan ride.
  16. Robert A
    Robert A Member
    Los Angeles
    New to Tesla and have a LR-AWD on order. How much do people typically pay to install the Comfort Adjustable Coilover kit? I'm in SoCal.
  17. T3SLAROD
    T3SLAROD Member
    SoCal
    Check out 365Performance in the Inland Empire, they charge $350 with one adjustment, no alignment though. They have done tons of Model 3s with no issues.
  18. BlackM3
    BlackM3 Member
    Note that if you're in SoCal and you want to have coilovers installed on your 3 and you're not sure which 3rd-party installer to go with, note that Unplugged Performance is based in Hawthorne, CA since 2013 and sells coilovers. I have switched my attention to Unplugged because I'm in LA and I like the idea of installation, adjustments, and support done by the company directly. Another factor was the Black Friday political post by Canada-based Mountain Pass Performance on both their website and this forum. Brief excerpt: "to celebrate this brighter future, if you’re in Georgia, Arizona, Michigan, Wisconsin, or Pennsylvania you’ll receive an additional 4.6% discount on your Black Friday order, just use discount code “byeorange". We don’t mean to be excessively political" .
    Just reporting the facts, this may sway you one way or the other, but good for people to know. Good luck!
    • Disagree x 4
  19. RB88
    RB88 Member
    Seattle, WA
    Any recommendations for installers in the Seattle area? One shop quoted me $1600 (including balance and alignment).
  20. Apone
    Apone Member
    Philadelphia Area
    If you don’t like politics, no need to inject it back into a conversation where no one was discussing it. I liked their post - shocking I know - people have very different and opposing views. And if we are reporting facts, maybe we should look at all the owners very happy with the performance of the product from mpp since we like like facts now....
    • Like x 4
