MPP Lift Kit Install Instructions, Range Discussion & Driving Impressions
Thats what I see
Trading our 3 in on a new Y and plan on getting the Tsportline 18" with Wildpeaks. Next will be the MPP lift kit and camber arms. I'm a noobie when it comes to suspension mods. Anyone know a good shop in the Denver, CO area to install the kit, or is this so basic most any place that does alignments can do this?
These guys did mine works great MPP will give you a few options of you ask them that's where I got this name from
Dave Bigley
Cryotune Performance LLC
6100 West 55th Place
Arvada, CO 80002
720.530.0532
I got it aligned at Firestone after
Reactions: COrental
which wildpeaks and size did you get? curious as to the range hit.. id rather not switch tires twice a year if i can help it
Nope, it’s 100% accurate, requires 8” width wheel with ET+35mm offset to allow for enough clearance to front upper knuckle.
Zero rub, not on full compression, not on full turn.
On an actual all terrain tire
Same thread:
im running 235/60/18s and dont have a problem... 225/50/18 is smaller than stock tires right?
