I've read the problem ends up being the motor can change speeds so quickly, and the torque rips apart the transmission like tissue paper.
need to add this photo to that text.
Fia formula-e rules specify 5 speed gearbox, but it does not make any sense. Gearbox is needed if your engine does not produce enough torque at low rpm.
I believe motor from Tesla M85 is cheaper, more efficient, more reliable and lighter than their gearbox-motor combination. It certainly has enough torque for a 900 kg car.
A gearbox in a Model S could get you more low speed torque or a higher top speed.The gearbox is needed to maximize acceleration at all vehicle speeds. The single speed Model S is very impressive at lower speeds but peters out at higher speeds relative to similar ICE vehicles.
Everything you could need, yes. but everything you could want? nah.I dont get this thread.
What could you want for a road car that the Model S doesnt offer?
sub 5s 0-60; 155 mph. Everything and more you could need from a road car.
I don't doubt the Model S drivetrain is cheaper, but for that application its not going to be more efficient and reliable over the Formula E spec units. And...I'd bet that the Formula E drivetrain is probably not that much different in mass than the Model S. The forumla E gearbox probably only weighs 25-30kg.
As it's a single manufacturer series right now, they also probably wanted to base it on existing Formula Renault series suspension elements where the gearbox was a structural member of the chassis.
You don't cut costs by adding a multi speed gearbox. Economy cars don't need blistering performance and a high top speed.
My first thought is when you're thinking mass volume, lower prices cars: Why would a cheaper vehicle have to have a top speed of in excess of 120 or even 110 mph?
Well...a great many things if you're asking, though none of them (IMO) have to do with the drivetrain. Tesla definitely settled on the right solution for a road car application.
I brought formula-E in as an example of how a multi-geared transmission can actually be the optimal choice for an EV, at least for a particular use case...the unfortunate misunderstanding of context by some sort of muddied that point, but...its just the internet so no biggie. :wink:
Oooh, interesting point. Yeah, that's a possibility.If anything I see a system similar to the ring gear setup with multiple traction motors of varying windings similar to how the Volt (Gen 1 car, Gen 2 is different) is setup. It's a complicated system to explain but think of it in the same way the D cars utilize two electric motors of varying size to increase efficiency. Several videos on the Voltec power train attempt to explain this.
A lot of people don't exceed 65. So I'm sure there would be no problem finding buyers that would be fine with a top speed of 70 or 75 and even more if it saved them $5k-$10k.
