I did notice a few more issues as I was cleaning up the car today.
I did manage to somewhat isolate the key fob issue though. I swapped to the other key fob and the issue goes away. My defective fob would randomly open the door and the car would never lock itself when I went inside. I believe its range is off and the car thinks that fob is closer than it is. I moved the faulty fob to the other side of the house and only use the other fob that came with the car and everything is much, much better. I'm going to ask for the SC to either get me a new fob or reprogram this one.
I found scratches on the inside part of where the FWD opens on both sides. They're basically white lines where I can see that the paint got rubbed off. I'm hoping that it stops at where it's at and doesn't keep eating deeper into the base coat. I would rather them not align the doors again to try to fix this. In fact, I almost doubt they'll be able to. Maybe a flat piece of PPF on each side would help me out enough with that. It's past where the PFF ends, so I'm inclined to leave it alone as long as it doesn't get worse.
