And I am "surprised" that you think I have not done so.That still doesn't answer why the PowerWall is not eliminating your Peak usage. Now, if you tell me that you're air conditioning 3,000SF to 75F on a 90F day, then I would understand. I am surprised that you have apparently not drilled down into the details to see exactly why.
My peak rate extends to 9pm for Monday to Friday. Of course my solar production tapers down to nothing in the late afternoon. As that occurs the Powerwall starts to discharge to reduce my grid draw during peak rate hours. And I have set the Powerwall to never go below a 30% reserve so that in case of a power outage, no matter what the time of day, I always have some backup battery power for when the sun isn't shining. The Powerwall is only 6.4kWh total available capacity. 70% of that is only 4.48kWh. That isn't quite enough to always ensure that I never use any grid power at the peak rate. To achieve that goal I would need two Powerwalls.
Even with one Powerwall I am using almost no grid power at the peak rate. That's good enough for me.
