I wanted to have full 48A charging so 60A circuit (continuous load of 80%). There seemed to be disagreements on 60A with 6ga, so I went with 4ga, installed in a near empty 100A sub panel in the basement close to the garage. Main 2 panels of the house are 100% full and hard to access / far.
The cable warms a little while charging, maybe 80F.
I only get to 30A at work
You made the right choice on the cable. NM cable (romex) is limited to the 60c insulation rating by code and so it only goes to 55a. Moving up to 4 gauge (or doing THHN in conduit) was the right call.
Nice clean panel!
Oh, and the neutral is totally superfluous. Was there a reason for that? (Wire that was available or you want to be able to do a 14-50 later?)
Yep, to switch to a 14-50 later, such as when moving. I had to use a dremel to trim the whole thing dang cable!!
The charging tax credit, not sure if renewed US retroactively extends tax credits for charger installations, electric motorcycles and fuel cell vehicles through end of 2017 (Updated)
Hands down the nicest install I have seen in 3 years perusing this board !...
200a service. My panel is fed from a dedicated transformer part way down my driveway. The buried wires are way over size (like most things I do), it could support 400a if a panel upgrade is needed. My total load at any one time won’t be much higher since the car charges at night. Other 240v upgrades like the plugs would only be seeing things like a welder or compressor, so all short duration loads. Total average for the house wouldn’t be much higher.
Nice setup! How did you connect the voltage input on the monitor to the HPWC fed and what is the switch above for?
