How about how it handles the Crest of a hill?AWD. and regarding the promises of true FSD with current autopilot hardware... well.... every morning when the low sun hits my model 3... i get periodically warnings about "limited blind spot detection" because the cameras dont work against bright sun light....
I personally went with the SR+ without FSD. I could “afford” AWD with FSD, however based on what I’ve read I’m 100% confident I’ll be happy without either and decided to make better use of the funds. I can always add FSD later if I change my mind, and snow tires are cheaper than AWD so I’m covered there also. Just something to think about.
What part of the country do you live in? From what I've seen the M3 does pretty well in the snow.I've driven AWD and RWD Model 3 with and without snow tires on snow and ice. Not even a remote question, the AWD barely matters, and isn't likely to make most drivers safer on snow. Get snow tires if you drive on snow. AWD won't make you stop or turn any better, and its not really any more stable unless you're driving hard. You don't need AWD, the dual motor car is quite bad on snow with the MXM4's, just the same as the RWD.
How do you handle it? There's nothing different about the how it will be handled, simply a matter of when the system will have learned the same mechanisms we have. Plus it will have non-human sensors to supplement.How about how it handles the Crest of a hill?
To answer your question, no, there is no lane changing capability with AP while using Autosteer. If you don’t turn AP Autosteer off before changing lanes you have to fight the steering correction which will turn AP off anyway.I have the AWD and FSD. If I was getting a new one today I would just get the AWD and no FSD because the included Auto Pilot does everything you probably want in the traffic you drive in.
One question I have for anyone that can answer. I know you don't get the auto lane change but can you still command it to lane change with the no FSD? I'd assume yes, since I use it now all the time but could be wrong since I have FSD. I'm talking about using auto pilot (no NOA) and I do a full stalk turn signal and the car changes the lane itself. If that is something with standard Auto Pilot then I definitely wouldn't get FSD.
Manual lane changes can be done, however, while keeping TACC engaged.
You have an unnecessary step. You can just hit the turn signal and then steer to only disengage auto steer and not TACC.You can always upgrade to FSD, can never upgrade to AWD.
I think you'll get more back for having the AWD. If your daily drive doesn't change speed limits all the time then speed limit sign recognition doesn't really give you anything, and I don't think auto lane change adds any value when you have to make sure that it's safe yourself anyway.
Autopilot will keep you straight while you check your blind spots, then you press the shifter up once to disengage AP (or if you're super-lazy like me: up then down, to disengage AP and engage TACC. I call this 0 pedal driving), pull into the neighboring lane, double press shifter to start AP again.
