Part of my reason for moving to 20" rims.
I also wanted a little bit more sidewall for contact patch compliance.
I do not think the camber bolt slop was sufficient to remove 1.4 degrees of camber (actually, really sure as my links were 0.210" longer and that took out a degree).
For those not familiar, Tesla had a few cars that were outside even their specs. They addressed this by making bolts where the bolt shaft was necked down to the inner thread dimension as opposed to the original bolts were the shaft was the outer thread dimension. When installed, these bolts were smaller than the holes they were installed in which allowed for movement between the chassis pick up point and the rubber bushing inner race it was clamping down on. The tech would then bias this "slop" to pull the top of the upright outward thus reducing negative camber. Tesla was now relying on the clamping force of the pick up point on the rubber bushing inner race and not the shear strength of the bolt itself.
I've not seen those before but it appears as though the eccentric bit is a larger diameter than the threaded area. Given the chassis pick up point is double shear, you would have to enlarge at least one ear of the pick up point to install them, wouldn't you?
Well, the bolt is loaded in tension only as you are using it to clamp the chassis pick up against the control arm rubber bushing ID. The bolt you are showing seems to allow for shear loading under the head. Either way, any quality bolt would be more than sufficient for the application judging from fastener sizes used on much higher loaded race car suspension.
Just my opinion and worth every penny you paid for it :0
I ended up machining up new upper links as I did not want to alter the chassis pick up points. Now that the cars are much more widely available and have a lot more miles on the fleet, I would likely consider those bolts today when I did not several years ago.
...did my own wheel tire package using Nurbergrings and Pilot Super Sports in 20". The aftermarket 20" package was half the price of Tesla's 21s with better wear and grip. I also got a very nice 10 lbs per corner reduction in unsprung weight.
Can someone post a link of where to buy the adjustable rear camber links?
I've found that living life can result in property damage, personal injury and always results in death.
Hi, I have read the entire thread. Thank you for all the great data and settings. I have chronic tire wear also. I'm at 116,000 Kms. My question is... I have a friend that is a certified welder. Do you think it would work to take the uppers off, wrap the ends or press out the bushings while there being welded, add in aluminium on both sides of the center and reweld? There is a section on both sides where the aluminium is solid? My car is a p85. May 13' (9904) so early uppers. Or do you know how I could get a set? Sending my links to get the bushings pressed out and installed at BBC NJ It will put my car out of commission for too long. Thanks for the help. Greg
