My comment on the newest rear upper link is that Tesla has moved from a rubber annulus joint inside and outside to a steel ball style joint on the outside and the original rubber style joint on the inside. Tesla made a change in the link design to accommodate the new outer steel ball style joint. The outboard bore is smaller to either increase the press fit or to accommodate a smaller joint OD. I did not measure the joint to determine why the bore was smaller; I only know that it is smaller.
I would suggest any links you might use should have the smaller outboard bore as using older, same bore inside/outside, links may have insufficient press fit to properly retain the new style outboard joint. Also note that the new smaller outboard bore size makes links either left side or right side depending on which of the two bores were left smaller. Put differently, you can no longer use just any link on any side of the car.
Lastly, you do not want to run zero toe in the rear as the rears will tend to toe out under acceleration loads. The wheel is pulled forward against the lower a-arm which causes the front side toe link to toe the tire out. I've used toe out on the rear of race cars to get them to rotate under acceleration but I would not suggest getting anywhere near this on a street car unless you are adventurous I set mine at 0.15 total (both wheels together) toe in on the rear.
