There is no such thing as 220V residential in the US except in a few rare cases since WW2. Is this an existing circuit to a different outlet? Unless the breaker/outlet is in poor/worn/aged condition you should be fine.
There is no 220V; that's just some old terminology from a century ago that grandpas still say. All residential electric in the U.S. is actually 240V.
Industrial commercial buildings have a bit different system that ends up having 208V as their higher version (don't need to get into why), but the breakers and other equipment can be used for that interchangeably on the 208V or 240V stuff.
In any case, to the OP, it doesn't matter. The car doesn't care at all, whether the voltage is 183 through 283 for sure, and probably an even wider range.
It should work from 200v to 265v. The big question that nobody can seem to answer is if it will work up to 290v (277v commercial power).
Teslas used to support 277v for HPWC installations. Do they still? Nobody seems to know.
Gen2 does work up to around 290 or beyond, although 277 support was removed from the manual in later revisions. I don't know about Gen3, but I bet it doesn't 'officially' support 277 either.
I've seen devices with all sorts of voltages. And more often than not people quote the wrong voltage when discussing it. But I've never seen an actual circuit breaker marked 220v.
Indeed, it's basically okay if an appliance says it's rated for 110V or 220V, but if the protective device has that rating, it would actually be against code to use it on a standard 120V/240V service!
