I think I just wet myself
I have been waiting forever for something like this to plug into the side of my quick220 box
Not to mention damn near every single motel in the country uses this for their HVAC units. Back the car up to the door, run the cord to the car and you are all set for a decent overnight charge.
As for the orientation, it is a little curious. I'm betting they found that 6-15s are equally likely to be installed ground-up as ground-down...
Wow, this is quite a surprise. I'm starting to get my hopes up that more may be on the way.
I am seeing something completely different (if the Tesla pic is accurate). I am seeing L1 or L2 in the "up" position, which is even more bizarre. Again, if the pic is correct, it would require the work box to be mounted sideways (SRSLY!?!?!?) for the brick and short cable section to hang/be supported vertical. Many motel/hotel 6-20’s are tucked in very close quarters directly underneath the heat, A/C unit where the workbox is indeed sideways and the power supply cord runs horizontal, this would not allow the Tesla 6-15 UMC to even fit (maybe that's Tesla's intent). Very confused here.....but glad to have another Tesla UMC adapter that charges at ~9mph, especially for owners that don't have the load calcs to permit a 14-50 now that the very desirable (for some) code adhering 14-30 is discontinued. As I have said several times:
more Tesla UMC adapters = fewer home made/3rd party adapters = fewer failure points = safer charging = higher TSLA
When I wired my workshop I used a 6-15 outlet for my table saw, only because I had run 14/2 romex. Had a hard time finding the outlet. Definitely obscure and much less common than the 6-20.
I'm still wondering why Tesla made this at the same time they discontinued the more popular 14-30 adapter.
6-15 plugs are compatible with 6-20 outlets, just like 5-15 and 5-20. You won't get the benefit of pulling 16A, and will be stuck with only 12A, but you can still plug in to that 6-20 air conditioner outlet.
Yes, I do know that, but that’s the weird move. 6-15 outlets basically don’t exist out in the wild; 6-20 outlets do. So what adapter does Tesla give? A 6-15 that limits the current to 12A, rather than the 16A we should be able to get.
Current (Breaker/Used) | 5-series | 6-series | 10-series | 14-series |
15/12 Amps | 5-15# | 6-15# | ||
20/16 Amps | 5-20# | 6-20 | ||
30/24 Amps | TT-30* | 6-30 | 10-30 | 14-30 |
50/40 Amps | 6-50 | 10-50 | 14-50# |
I agree, but there is no way that Tesla will make anymore 6-50 adapters, and will definitely not make any 10-50 adapters(the Roadster didn't even have a 10-50 adapter). The reason is very simple, the Model S UMC cannot take constant 40A charging without problems. Having said that, I have no clue why Tesla doesn't sell the 10-30/14-30 anymore. That is a very strange decision.Given the simplicity of the adapter, Tesla should just make all reasonable choices. Tesla probably could make a small profit, and at least break even, while offering wonderful support for their customers.
Below is my list. This is only 11 adapters, and in my experience would cover 99.99% or more of North American Tesla UMC charging needs. Getting rid of ad hoc/3rd party adapters and not having to remember to manually set the max current are huge advantages that justify having a full set of adapters available.
Current (Breaker/Used) 5-series 6-series 10-series 14-series 15/12 Amps 5-15# 6-15# 20/16 Amps 5-20# 6-20 30/24 Amps TT-30* 6-30 10-30 14-30 50/40 Amps 6-50 10-50 14-50#
*The TT-30 is not a 5-series connector, but is often found in RV locations, and can be very useful when nothing else is available.
#Currently available.
There's no reason they couldn't make those adapters and treat them the same way they've done the new Canadian 14-50, limit them to 32Athere is no way that Tesla will make anymore 6-50 adapters, and will definitely not make any 10-50 adapters(the Roadster didn't even have a 10-50 adapter). The reason is very simple, the Model S UMC cannot take constant 40A charging without problems.
You are either very lucky for your UMC to have lasted, or rarely use it. After about a dozen in three years, I have very little faith in the UMC.I don't know why you say that. My UMC works fine for long periods with the 14-50 adapter. Tesla ships the UMC with a 14-50 in the U.S. and recommends installing a 14-50 in the garage as a good charging option for a Tesla, charging at 40 Amps.
Why would a 10-50 adapter present problems that the 14-50 does not?
Is the UMC your only source of charging?My UMC has charged fine at 40 amps for 3 years...
My umc is my only source for normal daily charging. It has worked perfectly at home and on the road for three years.
