Wow!
@offandonagain super impressive work. I was playing around with the app several months ago, just after I decided ChargeHQ wasn’t really worth it compared to the ever increasing ability of Tesla app + CoS feature. NZ was pretty cool then, but automations were not capable enough yet for what I needed…or maybe I just preferred to keep in a single app still. Looks like you’ve done phenomenal work in only a few months. Kinda surprised Tesla is not just hiring you to run their app or at least buying your IP.
Anyways, nicely done!
Wondering if you or maybe someone here can short cut me on a quick answer if my scenario can be managed with the current capabilities in NZ?
TL;DR - I’m about the get my PGE annual true up and am probably going to be hit by high NBC’s. I think Netzero may help me mitigate this next year.
Util: PGE
Rate: EV2A (so largest peak / off-peak spread)
PV: 11kW Tesla w GW2
ESS: 2x PW+ and 2x PW2, PTO+GC+EE all “on”
Current ESS Config: TOU, only slight tweaks to EV2A rate plan, 0% reserve on normal, 0% reserve on VPP
Vehicle: 3x MY, all set to CoS (30% guaranteed and 90% on solar)
EV charging HW: 2x wall connectors
Overall, I’m a substantial net consumer of kWh per annum (technically mWh) due to the multiple EV’s. However, I’m effectively net zero (ha!
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
) for cost, due to being on NEM2 and using the 4 PW’s to time shift my EE into the peak hours, and also allowing me to never pull home load from grid in peak. If I don’t have enough PV production in winter, I can GC PW’s to 100% SoC and the effectively arbitrage those kWh’s into peak window back onto grid. Unfortunately, PGE is increasing prices overall (which in theory shouldn’t hurt, could even help) but decreasing the EV2A peak/offpeak spread (which does impact the financials negatively)
My quandary, and why I first looked into Netzero several months back, was that I thought I wasn’t fully optimized from the financial perspective. I’m approaching first PGE true up (was supposed to be 6/5 but still don’t have it from them) and it looks like this to be true…my NBC’s minus PCIA minus MDC will far (far!) outweigh my “NEM Charges before taxes”. I got a little overzealous with the PW NEM arbitrage, and it will cost me $$$.
Tesla’s CoS somewhat is improving this, since almost every day one of the EV’s is connected to the wall connector during peak sun. But it would really be better if the PW’s filled up first, and I noticed this isn’t always the case. Also, prob more significant, my PW’s frequently fill to 70-90% SoC during the night using GC, when they really don’t need that, if they just waited a few more hours the sun would take care of it.
So I’m looking for a way to allow the PW’s to GC a bit, to say 50%, right after midnight. Then turn off GC, until maybe 2p in case it needs a final top up. If I leave the PW’s on TOU this whole time…with current PGE EV2A rates, I’m guessing that the PW will try to hit 100% SoC using the only means now available, solar. Does this seem correct. If by chance I have extra PV, it will just get slurped up by one of the EV’s using CoS…so no “wasted” PV exported to the grid prior to 3p should happen.
Is it really that simple?
Any thoughts id better or more robust to set to turn off GC at 1:01a every night (I charge at 22kW) then add another automation to turn GC back on at 2p?
Or is it better to set to turn off GC at 50% SoC, then turn on GC at 2p each day?
Why has Tesla not accommodated this considering they have a lot of PGE customers I would assume? Anyways, thanks again for the app!
